FlySky GT-B3
  • macace123
    Robotics Operator
    • Mar 2013
    • 477
    FlySky GT-B3
    Anyone know how to bind this thing i got the servo bound i cant get the motor esc help please
    Its not the boat its the driver http://namba2016fenats.com/
    Whiplash,Sprint Cat, Pursuit, 83' Miss Rock modern hydro JAE21, Dragon M11 Tunnel, Mickey Beez Jet, CF JAE21
  • NativePaul
    Greased Weasel
    • 2764
    Binding is TX-RX, if the servo works when you move the transmitter stick/wheel, it is bound.
    I don't have that radio or know what your problem actually is though, sorry.
    Is the ESCs RX lead in the right way round yelllow/orange left, red middle, black right, same as the servo?
    Is the ESCs Rx lead in the correct slot? trying the others wont hurt anything.
    Does anything happen at all? if you get beeps you might try reversing the throttle channel on the TX.
    What motor and ESC is it? Maybe someone has the same combo and can help you more, or if it is a sensored ESC with no sensor lead plugged in you shouldn't expect much.
      • 7990
      We also need to know the exact ESC and if the ESC worked with another radio. A friend has that transmitter (I believe) and he had trouble getting the ESC in one boat to work correctly - needed some "special" programming...
      • Fast Guy
        • 135
        FlySky is like Futaba, you have to reverse the throttle channel to get most ESCs to work. Then follow the ESCs instructions for setting up the throttle end points.
        • oscarel
          • Dec 2009
          • 2135
          And failsafe
          Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 Beta
