Elogger, AND telemetry?
  • runzwithsizorz
    • Jan 2009
    • 901
    Would it be possible to split the wires of a temp. probe, and rpm sensor to feed info to both the elogger, and a Spektrum Tx?
  • siberianhusky
    • Dec 2009
    • 2206
    Don't think so, it would be getting voltage from both the logger and the esc. Not even sure if both use the same voltage on the sensors.
    I wouldn't bother with the SPektrum Telemetry, it's pretty much useless in a boat. Tried it in a nitro boat once to see if I could get exhaust temps.
    Once your boat is setup what is there to monitor anyway unless you make a change? I use my eagletree all the time for setup but don't bother with it unless I've made a serious change to the boat.
    Once I know the amperage etc, all the extra connectors are just more resistance and another potential failure point. And a chance to lose my logger if the boat decides to leak or gets hit during a run by another boat.
    Broke my power panel last week when the velcro let loose in a barrel roll, wedged itself between the collet and motor! 35$ down the tubes! Wish the boat had landed upside down instead of upright and pointed in the right direction!
    • runzwithsizorz
      • Jan 2009
      • 901
      Originally posted by Mike Caruso
      Eagle Tree works great, down side I have to un tape hatch to reset logger even just to make a prop change. Two runs today one prop change and the motor must have lost power.
      I take it you have an exterior switch? As far as reset, wouldn't you be able to tell the difference of the prop change by the TIME on your logger?
      • runzwithsizorz
        • Jan 2009
        • 901
        Eagle Tree recommends less than 6 volts. Telemetry RX, servo, and everything else is powered by a 2s through a UBEC at 6 volts, ( rx,& servo could take up to 9volts, alas, none of the other stuff can).
        I am ALWAYS tinkering, and making changes, and it's nice to know if I can stay out on the water, or need to bring it back in. If I am racing, or just on the water with other boats I don't use it, for by this time,
        I already know what dialed in is. Really got the Jones for the wireless Seagull Dashboard, and with a long usb cord to a laptop, others/crew could see whats going on live. Guess I could just buy another temp, and rpm sensor.
        Sorry bout your panel, mine is also just velcro'ed, ----- inside a water proof Lock N Lock box.
