E- logger+ Spektrum??
  • runzwithsizorz
    • Jan 2009
    • 856
    Can the temp., and RPM probes used with the Spektrum telemetry RX's be used with, (plugged into), the Eagle Tree logger v4????
  • siberianhusky
    • Dec 2009
    • 2184
    Yep, you just have to change the pinout of the plug. Works with the temp sensors for sure, no idea about the rpm.
    • Cooper
      • Jan 2011
      • 1137
      i didnt know that, can you tell me specifically what pins to change. i have the speky temp and that is the only et sensor i didnt get , thanks
      • siberianhusky
        • Dec 2009
        • 2184
        Can't remember what they originally were but now they are centre and one side, leaving one end pin empty. Didn't even need to calibrate them, the ET logged the temp of my hand to be a couple tenths low.
        Works for both the motor and small sensor, I only use the small one on the caps and log volts and amps and the one temp.
