A Simple and Reliable 2.4GHz Radio?
  • 10gauge
    • 281
    What is a simple and reliable 2.4 GHz radio that has steering trim? I haven't been running FE boats for about 4 years at which time these microwave band radios were just coming into the market. I am trying to get back into the hobby, and convert my 75MHz fleet. I tried the Tactic radio on my UL-1 and it's very glitchy - it takes 5 minutes to initialize the motor, even after adjusting for the throttle trim. Is there another radio that every likes and is readily available?
    Thanks
    Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
  • Heaving Earth
    • 1877
    Tactic needs throttle channel reversed and throttle trim all the way up.
    Tactic is the simplest best radio for boats IMO
    • monojeff
      • Nov 2010
      • 2551
      I have been using a flysky gt3 for over a year and had no issues.
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • motorfixer1
        • May 2012
        • 36
        I have a spektrum dx2-s and it is great but on the expensive side. I also have been running the HK gt-2 system and have no complaints as of yet. Small reciever size and low price make the HK radio my favorite.
        • Basstronics
          • 2303
          Im using the fancier flysky gt3 radio on multiple receivers.
          The unit is $40 for the radio/receiver. One radio will allow like 8 or 10 (cant remember off hand) models programed/saved.
          If you want REAL cheap the Hobby King 2.4 can be had for $20 in the USA warehouse. Note HK receivers and Flysky receivers are the same and can be used with either radio.
          • Heaving Earth
            • 1877
            I also use the flysky gt3. Great radio. But not as simple as tactic to set up IMO. I figure you have the tactic, use it.
            • MassiveOverkill
              • 139
              HK is always out of stock in both the US and Global warehouse of the GT2. I got Aaron to start carrying it. A little higher, but no shipping, and of course, the shipping time from China:
              • 10gauge
                • 281
                Thanks guys! I'll keep the Tactic and purchase another Flysky GT3/2 just to try out. WOW! Radios have gotten cheaper - can't go wrong with $28. I wonder, if I can still use my Hitec HS 545BB servos with a 2.4GHz radio?...
                • Basstronics
                  • 2303
                  Yup no issue.
                  http://www.hobbyking.com/hobbyking/s...Ch_Tx_Rx_.html
                  http://www.hobbyking.com/hobbyking/s...io_System.html
                  • 10gauge
                    • 281
                    Thanks Bass!
                    • Basstronics
                      • 2303
                      One BIG word of caution. These dont like to get wet. If you get the receiver wet its basically junk.
                      Corrosion X is a MUST.
                      • Fast Guy
                        • 135
                        I also bought a FlySky GT3B to use with my smaller boats and rock crawlers. Once I had the radio for a while I found that it worked very well having as much range as my Futaba 4PL and felt very much like the Futaba. The receivers are only $7.40 ea. I recently upgraded the firmware on the GT3B and it now has more features than my 4PL.
                        - 3-8 channels
                        - 60 model memory
                        - Sub trims
                        - More trim value (up to 99)
                        - copy models
                        - fixed expo
                        - Model reset
                        - Channel speed
                        - 4WS Mixing
                        - Dual ESC Mixing
                        - Dual ESC steering
                        - Multi Positions Switches (Up to 8 True positions out of a single push button)
                        - Key Mapping (any key can control any channel in many different ways)
                        - Calibration Menu
                        - Key Test Menu
                        - Backlight on time
                        - Inactivity Alarm
                        - Adjustable Low volatge warning
                        - Adjustable Maximum End Points (Up to 200% i think)
                        - Adjustable dead zone for steering and throttle
                        - Turn keep beeps on/off
                        - Adjustable long press delay
                        The Trim and d/r keys can do this
                        - nothing, it is possible to assign each button individually as key
                        - trim of channel 1/2
                        - dualrate of steering/forward/back
                        - expo of steering/forward/back
                        - change channel "n" value in range -100...100
                        - subtrim of channel "n"
                        - 4 wheel steering mix -100...100%
                        - DIG throttle mix -100...100%
                        - Multi-POsition, switches position up/down
                        - steering speed turn 1...100%
                        - steering speed return 1...100%
                        They Can be setup to act like this
                        - momentary, hold left/right trim key to get end values,
                        when nothing pressed, servo is at centre
                        - no long keys, long press is the same as short press
                        - autorepeat is on
                        - long press of one of trim keys will reset to
                        centre/reset value
                        - long press of trim key will set to coresponding end value
                        And they can have an adjustable step rate, opposite click reset, reversed, etc.
                        And the Keys (ch 3 button, back button, end button, and the trims if set individually)
                        - nothing
                        - switch channel "n" value from one end value to opposite end
                        value.
                        - reset value of channel "n" to centre
                        - switch crab (CRB) no-crab (NOC) for 4 wheel steering
                        - switch DIG mix between -100 and 100 (more useable when using
                        return to previous val key setting)
                        - Multi-POsition, switches position up (at END back to 1.)
                        - Multi-Position Reset, switches position to first one
                        __________________
                        • 10gauge
                          • 281
                          Thanks Fast Guy for the detailed list of upgrades. How do you upgrade the firmware?
                          Thanks
                          • Fast Guy
                            • 135
                            Thanks
                            flysky-gt3b-transmitter upgrade
                            Check out post #3000
                            gt3b-hack-question-answer-thread
                            I did the firmware upgrade myself but it takes some soldering and computer know how. There are many that offer the service for a small fee in the USA and Canada.
                            • Heaving Earth
                              • 1877
                              What happened to simple? How many useless features do you need for an Rc boat?
