TS3 radio box mounting...suggestions?
  • capnswanny
    • Feb 2012
    • 867
    So I'm finishing up the box for my ts3, I was planning to use 3M double sided tape to hold it down, same tape I use to hold the rear sponsons on my rigger, is this a good idea? I know I'm a bit behind the times for new builds, but I'm looking forward to seeing this hull carving the lake! Thanks! Corey
    This is NOT a toy?!?
  • Diegoboy
    • Mar 2007
    • 7443
    Does your box need to be removable? Exactly what 3M tape are you talking about? The foam mounting tape or the grey putty-like tape used to mount car emblems?
    • capnswanny
      • Feb 2012
      • 867
      The grey putty like tape....cut it of with a guitar string type stuff. I just like the idea of possible remove...
      • Diegoboy
        • Mar 2007
        • 7443
        If it must be removable, that's what I would use!
        • capnswanny
          • Feb 2012
          • 867
          Thanks!
          • capnswanny
            • Feb 2012
            • 867
            Would you advise against removable? I would certainly epoxy it in if there were gains from it.
            Thanks again for your advice.
            • properchopper
              rcgoatbuild@snotmail.com
              • 7708
              Corey , Once upon a time I has two TS-2's where I could transfer the box between them. Might give this concept a thought :
              DSC00731.JPG DSC00732.JPG [ATTACH=CONFIG]80134
              [/ATTACH]DSC00735.JPG
              I've found that for many applications tape works well but after it gets wet (as it will in the TS-3) it loses it's gripping power.
              • capnswanny
                • Feb 2012
                • 867
                I like it! Thanks for the pictures....a thousand words!
                Perfect option for me since I over cut a bit aft, wood will fill it on nicely!
