Weirdest radio problem.. EVER
  • Boaterguy
    • 1779
    well, I tried binding a new hkt6a RX to my TX because the old one suddenly lost range.
    everything was working perfectly, I removed the bind plug after binding and everything was working fine. I unplugged the batt and plugged it back in, the LED blinked and went out, strange. so i tried it with a servo and same thing.
    I tried it with a GWS be-found that beeps when there is no signal.
    it beeped on plug in and then nothing, but the power LED on the be-found was still blinking, showing low voltage (i was using a 6V rx pack, it was at about 5.5v or so.)
    i unplugged everything and went for broke, plugged the RX pack in backwards, it worked, surprisingly.
    then I plugged in a servo and the LED went out again.. ugh.
    I bound to another RX (same type) and had the exact same problems.
    I then proceeded to bind the two RX's to another TX, they both worked fine.
    I tried the same procedures with a third RX, same thing.
    I just don't understand how binding to a different TX (that was working about 2 weeks ago, last time I used it) would make the RX do this, any ideas?
  • JimClark
    • 5913
    Ok it's a Hobby King radio? enough said
    Billy Graham
    • TheShaughnessy
      • 1461
      No idea what is going on but I just got a flysky 9 ch tx and 8 channel rx. I had one that was doa and then the next one bound to the tx but with the servos plugged in. The led didn't come back on. Had them exchanged for 2 new ones that just smoked when I tried binding. Now I'm trying to get refunded so I can just pay the extra coin for an rds8000. Would having the power in backwards with the bind plug in fry the tx since the signal and negative wire are linked so to say? Looks like we are getting what we paid for...
      • Boaterguy
        • 1779
        but nothing was DOA, the only thing that changed was I modded the TX to a deans plug to run a nimh pack.
        the receiver works fine.
        • TheShaughnessy
          • 1461
          im pretty sure i tracked my problem to an issue with the bec in my speed control.
          • Boaterguy
            • 1779
            i'm running an RX pack
            the weirdest part i find is that binding to a different TX changes the mechanics of the RX
            • TheShaughnessy
              • 1461
              I always thought the tx was the brains of the operation. If it were the other way you'd probably program the rx.
              • Boaterguy
                • 1779
                it is, but the workings of the RX get changed when I change the TX.
