Brushless Reef Racer not as fast with 2.4GHz Radio
  • domp444
    • Jul 2009
    • 901
    Hey again! My little brother has a Reef Racer 2, which I converted to brushless last year. He's been using a crystal radio so I decided to move it up to 2.4GHz since I had an extra rx. It is a Tactic Pistol 2.4 radio. We put it in the water, and what a disappointment. It wasn't going nearly as fast as before. I believe the problem is that there is no D/R or Throttle Rate Trim on the radio. Since the throttle is reversed, I believe it's not able to reach it's full speed.
    Here is the configuration:
    Great Planes Ammo 28-45-2700
    Great Planes Silver Series 25A Brushless ESC
    I'm also using a PiStix adapter to allow me to use a Pistol Radio with an airplane ESC.
    Anyone know what I can do to get it to work as before? I wouldn't wanna go back to the crystal radio, it's a lot safer for him without the huge antennas.
    SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
  • 1truckerdan
    • Aug 2011
    • 344
    Check your "end point settings" for the throttle channel on your old tx/rx might be set (higher) different than the new one.
    Daniel
    When you know it all.......you never will learn anything new
    • domp444
      • Jul 2009
      • 901
      The crystal radio had a "D/R" trim nob, but I think that is for the steering rate now that I think of it.
      That is what I was thinking about the EPS. How can I change the EPS for the throttle channel on my new one?
      • 1truckerdan
        • Aug 2011
        • 344
        Here is the Tatic page for the TX
        I don't see any adjustment for the throttle EPA .....
        I wonder if you bind it with the throttle centered off (towards more brake) if it might work.
        I have not had any experiance with the TX/RX you have......so I am just trying to help come up with ideas to try.
        Hopefully someone else will chime in
        Daniel
        • domp444
          • Jul 2009
          • 901
          Yep, there isn't an adjustment for the EPA. To bind it, I have to go to full throttle and wait for 3 beeps. It would seem that when I bind it full throttle it would recognize where full throttle is and work.
          • Rich
            • 581
            I have that esc and have used it in my Gecko, I never had to use a PiStix to adjust it. Try recalibrating it with out it. I will be a pain in the butt to get it to work though. You have to play with the trims and throttle reversing to get it to work. If not, is there a throttle calibration with that esc, I don't recall if there is one or not.
            • domp444
              • Jul 2009
              • 901
              Without the PiStix I have to hold the trigger all the way back. I tried adjusting but it wasn't going well so this solved the problem. Much easier to arm and disarm the ESC this way.
              Tried the boat again today, but I think we're gonna go back to the crystal radio unless we can solve this problem. The boat goes significantly slower and is not as much fun
              • Rich
                • 581
                Come to think of it..what voltage battery are you running?
                • domp444
                  • Jul 2009
                  • 901
                  It is a 2s LiPo.
                  • Rich
                    • 581
                    Hmm that's weird, the only thing I can think of is its not seeing what full throttle is on the tx, give the other radio a try and see if the problem still persists.
                    • domp444
                      • Jul 2009
                      • 901
                      That's also the only solution I could come up with. I'll try it again with the crystal radio next time and see what happens.
