flysky radio
  • dano1
    • Dec 2010
    • 403
    flysky radio
    have a flysky radio i put in a mono that i just finished buiding, its a gt3b system, ran the boat a few passes to get glitches out and the dang thing is dead now and not getting a signal, anyone run these things?....it has a fail safe built in to reciver
  • FE Wannabe
    • Jul 2007
    • 626
    I have one. Are you getting any lights on the receiver at all?
    Did you get the receiver wet?
    • SweetZ28
      • 1322
      I have the flysky i never had one problem i run them in 10 RC models.... try rebinding it make sure ABS brakes are off on the radio.
      also with the gtb3 radio after every setting adjustment you make you have to press the enter rotery button down or your settings won't be stored.
      Also when switching to a new model you must first switch to the model press enter and shut off and turn back on the radio or your models settings won't load correctly and end point settings change and maybe trim settings.
      WWW.PPRSLOTS.COM
      • dano1
        • Dec 2010
        • 403
        Im getting no lite on the reciever now, no...it didnt get wet, ive run it on another boat with no troubles, it just stopped responding like batterys were dead, im running the bec connected, i really havent dug into it yet for trouble shooting but im surprised it just quit like it did, i was in a no wake zone...ha ha....and it just stopped. The only thing i dont like about the transmitter is its easy to make a missadjustment in hand when your running, the grip has the buttons on it, the radio has 2 passes on it
        • dano1
          • Dec 2010
          • 403
          Im only running one boat on the system also, ill check the settings but as i stated ...its strange it just stopped like it did
          • SweetZ28
            • 1322
            don't worry about water these flysky 2.4 RX's can run under water they don't get harmed by water.
            WWW.PPRSLOTS.COM
            • SweetZ28
              • 1322
              I put a flysky modual in a ko propo mars , mars R and ex10 helios great radio's with all the features you ever need and no problems but you get to buy the cheap FS 2.4 $7.00 RX's to boot!! no prblems with these set ups!!
              WWW.PPRSLOTS.COM
              • FE Wannabe
                • Jul 2007
                • 626
                Dano,
                Are you sure your BEC is good and providing between 5 and 6 volts?
                If it is then you may have a bad receiver.
                • dano1
                  • Dec 2010
                  • 403
                  im going to put a external battery pack in it and try it again to see if its a bec issue, like i stated i just got the boat running so it could be several things, glad someone else is running these radio's....there a tad confusing setting up first time
                  • SweetZ28
                    • 1322
                    Try that it may work.
                    Here is my KO converted to flaysky 2.4 radios... also am doing a mars R!
                    WWW.PPRSLOTS.COM
                    • dano1
                      • Dec 2010
                      • 403
                      The esc is out of my kos....that could be a serious problem right off the bat, i have a 125amp turnigy that has something funk going on with it but i reprogrammed it so i may try that one again, where should the stinger be setting on that little jewel?, im about level with the hull now.....mabey a tad down
                      • dano1
                        • Dec 2010
                        • 403
                        Its the prince knock off i bought from brad
                        • dano1
                          • Dec 2010
                          • 403
                          bec bad in esc , put a external pac in and all came back online, thanks for the info guys
                          • FE Wannabe
                            • Jul 2007
                            • 626
                            Glad to hear it was just the BEC in the ESC.
                            Although, I am sure the ESC cost a lot more than that $7 receiver!
                            Got to love the price, i just outfitted the last 5 of my surface RC vehicles with these receivers for less than i sold my last used JR RS300 synthesized receiver for on eBay.
                            • SweetZ28
                              • 1322
                              Yea pick up a old KO PROPO radio for 60 bucks or so used and buy the flysky modual put it in and you have one of the best radios going!!
                              Got to love it!!
                              WWW.PPRSLOTS.COM
