Originally posted by sailr
View Post
Tactic Radio Problems?
I try to get the picture of it as the rx is damage by accident as I forgot that cc bec can handle only 6s max, so I put 8s so you know what happen. 2.4ghz antenna wire should be use, other wire like those am & fm will not work.Stiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"
Very interesting. Where do you get that kind of wire? How long should it be?Mini Cat Racing USA
www.minicatracingusa.com
can get from here http://www.himodel.com/radios/150mm_...vers_2pcs.htmlOriginally posted by sailr View PostVery interesting. Where do you get that kind of wire? How long should it be?
or if you have a defective 2.4ghz rx, the antenna can also be use. The length is not important, just as long as the wire protruding outside the hull just like the normal 2.4ghz rx. The most important is the top end of the wire which already being cut. Sorry for my bad english but Ihope you can understand what Im trying to sayStiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"
Hi tower hobbies has the 6channel tactic RX's for $19.99 they show a photo and they have a antenna already... you can probably use one of these.
http://www3.towerhobbies.com/cgi-bin...?&I=LW6039&P=E
Tower site says it will only work with their TTX404 Stick type transmitter. Too bad. I wish they would upgrade their surface transmitter with some model choices, etc.Mini Cat Racing USA
