do spektrum air receivers work good on water?
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    I use a dx7 and a ar6110 in my rescue craft. Absolutely no problems. Never did the rx come back with error codes.
    • H2OCamel
      FAST ELECTRIC EVERYTHING
      • Oct 2007
      • 494
      The 2.4 systems are not under the same leagal issue. look at the 2.4 gig surface radios and the air radios they do not have stamped on them for surface or air use only! All others 75Hz and 72Hz do.
      "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
      • egneg
        • 4759
        Thanks for the correction - I thought they were as the are still sold as surface and air separately.
        IMPBA 20481S D-12
        • NativePaul
          Greased Weasel
          • 2770
          That was the main reason for my switching to 2.4ghz so I can fly my boats and planes, and drive my cars with the same radio, and do so away from sanctioned fields tracks and ponds without the interferance risk of getting shot down by an unseen person in their garden .
          • MARKY C
            • Jan 2011
            • 37
            put it this way if you were using one of those land /water /air hydro planes then you would be in the s... would that mean you would have to change tx and rx when you take of from water to air. i dont think soo. i have used my dx7 with ar500 in boats and they work just fine. the only issue with this receiver is its not a marine waterproof one but you can buy them.
            • martno1fan
              • Jan 2011
              • 238
              Originally posted by the savy fluxer View Post
              do spektrum air receivers work good on the water?
              justwondering because i have a surplus of them.
              thanks
              No they do not,use Futaba Fasst or Marine rx for the Spektrum.
              • the savy fluxer
                • Jan 2011
                • 83
                well i have got a mixed bag of comments on this topic, so i think im going to have to try and find out for myself.
                thanks for all your comments everyone. and i will report back if i have any issues
                • cacofonix
                  • Jul 2008
                  • 243
                  hi there
                  i have a DX3R for about 2 years now, with 7 AR3100 receivers
                  in 7 different FE hull
                  absolutly no problem
                  i just buy a 2nd one for my son
                  herve
                  • Darin Jordan
                    • 9446
                    Here is what one of my Spektrum contacts relayed to me:
                    The DX6i and AR500 can be used in a boat just fine. The AR500 is a full-range rx.
                    DSMX is an Xtension to DSM2. They can be used interchangeably. Air DSM is different than Surface DSM and Marine.
                    So basically, I'd say that if it's a DSM2 or DSMX (not likely the later, just yet, but they were just announced!) transmitter, then any DSM2 compatible Rx will work. The Air Rxs will have a better range over water than the DSM2 surface RXs (SR-series... SR3100, etc.) The Air systems have a higher power.
                    The Marine RXs/TXs use the same protocol as the Air (and different than Surface), so they have the higher power, and better range, when compared to the Surface Rxs as well.. (Over WATER, anyhow).
                    Darin E. Jordan - Renton, WA
                    • G1ST
                      • Dec 2010
                      • 351
                      So it sounds like you can bind a AR6110 to a DX3S and use it in a boat.
                      Am I right?
