Bec or Not on Tactic 2.4
  • Jeff Wohlt
    • 2740
    For some reason I do not know if my AC 2.4 Tactic radio is BEC. Running a SK180 and just wondered if I need to remove red wire and run a batt pack. Or just plug it in to the ESC radio plug?
    I think I have lost it!
    www.rcraceboat.com
    jwohlt5362@yahoo.com
  • egneg
    • 4759
    The ESC determines whether or not if you need a battery pack. If it is an opto you need one.
    IMPBA 20481S D-12
    • Jeff Wohlt
      • 2740
      Ah....not sure why I thought the rec had to say BEC or not. It is a SK180 so I know it has BEC.
      Thanks
      www.rcraceboat.com
      • Shooter
        Team Mojo
        • Jun 2009
        • 2751
        Funny, I asked the same thing. The older Futaba RX's (1980's) used to have BEC written right on them. I learned the hard way and BEC'd a non-BEC. Oh...the smell!!! I think we used to run full batt voltage (7.2) to the RX's....can't remember. Sure have come a long way with batts, TX, and RX's. This 2.4ghz stuff is amazing!
        • draughted
          • Jan 2010
          • 8
          i for one have the tactics 2.4ghz receiver and i know for a fact that the receiver draws a lot of power. so a non switch mode bec will be in sufficient at anything over 7.4 volt.
          i would just make sure you have a proper switch mode bec of sufficient amperage if you use a high voltage.
          • carlcisneros
            • Jan 2010
            • 1237
            run a sperate receiver pack and be done with it.
            can't go wrong there.
            • sailr
              • 7128
              once again... the receiver has NOTHING to do with whether it's BEC or not. That is strictly a feature of the ESC. If your ESC doesn't have a BEC you have to run a separate receiver pack. ...and vice-versa.
              Not sure where you get that the tactic receiver pulls a lot of power? Receivers don't pull but a few milliamps. If you're getting short battery life, then it's your servo/esc that's pulling it down, not the receiver.
              The tactic works just fine whichever way you want to go, with, or without BEC type ESC.
              Mini Cat Racing USA
              www.minicatracingusa.com
              • draughted
                • Jan 2010
                • 8
                perhaps i was just using to large a voltage.
                it happens it was not a switching bec and i just wanted to make the point that it does not matter if the reciever has a rating it just need plenty of power.
