so I have a question... will it kill my reception to put the Tactic 2.4ghz radio in a balloon to keep it from getting wet? was thinking to put it in balloon and tie then velcro to bottom of hull? anyone done this?
Tactic Reciever... in a baloon?
i did it in my mini hydro,,plastic hull seamed to be fine, didnt try to go out real far but had no probs either....
I waterproofed my tactic rx, super easy, super quick & super cheap!!! I had it fully submerged (dont ask howOriginally posted by JMSCARD View Postso I have a question... will it kill my reception to put the Tactic 2.4ghz radio in a balloon to keep it from getting wet? was thinking to put it in balloon and tie then velcro to bottom of hull? anyone done this?
) and worked flawless!
A bought this at Harbor Freight and love it. I use about 5 coats with 15ms dry time in between and then let sit overnight after the last coat. I placed a piece of foam over the connection plugs so they wouldn't get covered.
Just don't use a CF balloon, Jason.
You can also conformal epoxy your receivers - then all you need to do is air them out if they get dunked."Look good doin' it"
See the fleet
Balloons have been used for a long time. At best, they make the Rx splashproof but not immersion resistant. Sealing the electronics doesn't always work and can trap moisture in. I "splashproof" my Rx's with three plastic bags in different directions to keep any splash or bilge slosh away. Best shot is to pressure test all cooling lines, float test, and use hatch retention devices & tape up REAL GOOD. Of course, anything can happen (and often does)!
[ Rx pulled out for foto, normally tucked away]Attached Files2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
CorrosionX works to waterproof receivers as well.
Remember to open up your balloon to dry out when your done.Namba District 16
I flipped my ul 1 when I 1st bought it.I didnt use enough hatch tape to go around the whole peremiter.(Ran out but had to run it).Everything was submerged.I got it back and got the water out,plugged it back in and ran it.Maybe it was a stroke of luck.I ve had no problems with it since.But,coating and trying to water proof is always a good idea.
Proper do you use anything else to like corrosion x? or just the bags? I already have corrosion X so sounds like I should just go that route? and the bags....Originally posted by properchopper View PostBalloons have been used for a long time. At best, they make the Rx splashproof but not immersion resistant. Sealing the electronics doesn't always work and can trap moisture in. I "splashproof" my Rx's with three plastic bags in different directions to keep any splash or bilge slosh away. Best shot is to pressure test all cooling lines, float test, and use hatch retention devices & tape up REAL GOOD. Of course, anything can happen (and often does)!
I am planning on possibly running my Tactic in my big MHZ cat..... the hatch isn't carbon fiber but there is carbon fiber in the boat... motor mounts/battery trays.. etc., will this be a problem for the tactic... should I use one of my FM radios I have sitting around.
The tactic works fine inside a balloon or bag. I run tactics in all of my boats. They all have carbon fiber floors in them. No worries.Mini Cat Racing USA
www.minicatracingusa.com
I put servo and esc extension leads into the receiver and put a blank connector into the third channel hole and seal the whole thing up. It works well and can withstand submersion. BG
this is great info too.... the servo extensions make sense too!! thanks encoreman!!Originally posted by ENCORE MAN View PostI put servo and esc extension leads into the receiver and put a blank connector into the third channel hole and seal the whole thing up. It works well and can withstand submersion. BG
