I know a few of you guys use the Tactics/Towers 2 channel surface systems with no hassles and I like the fact that recievers are cheap but what do you recommend for a 2.4ghtz system with 10 model memory? Are some systems better than others in waves? ie. spektrum marine?
2.4ghtz Computer Radio
i use low budget parts and i have the new airtronics mx-sport fhss-2 it is $100 and a great 2,4 radio has every thing you need to dial in and 10 model memory its also 3 channel
Thanks guys, both look great and I guess the price for extra receivers is pretty standard with the bigger brands.(you almost get the radio for free with the airtronics!!).
Is the fact that I will be using this model in swell so I will frequently not have direct line of sight with the model something I should consider in the type of radio gear I purchase?
I have a 3pm, 3pk, dx2.0 and a dx3.0... I just bought a tactic 2.4ghz and 7 recievers.... I like the fact the trims are all analog... makes setting up with esc's easier and adjusting for other models quicker... with boats for me anyway I think the tactic is all the radio I need..... the only thing that would be nice would be steering EPA in case one way of travel needs to be "tuned" down not to interfere with the prop or other hardware.... but for what its worth I like the tactic alot and I've used alot of higher end radios... but will reserve them for my cars/trucks...etc..
And as far as range goes the Tactic is fantastic and the realism of no external antenna is GREAT:) and convenient with less points of water entry possible... again great for boats.... I am even running the tactic in my 39" df with a lehner and hv240..... basically using a $60 radio on a $1300 Boat... I feel that comfortable with it..... it has been great so far....even though I just started using it a couple weeks ago I have no concerns that it will be replaced in the near future...
The Airtronics is the best deal on the market right now and they are ROCK SOLID! Can't beat it!Mini Cat Racing USA
www.minicatracingusa.com
Check out this threadOriginally posted by Salty View PostI know a few of you guys use the Tactics/Towers 2 channel surface systems with no hassles and I like the fact that recievers are cheap but what do you recommend for a 2.4ghtz system with 10 model memory? Are some systems better than others in waves? ie. spektrum marine?
http://forums.offshoreelectrics.com/...ad.php?t=13926
I think upgrading to a better radio with multi model memory is the way to go name each model and set and forget it
2 SV 27's and Vac-U-Pickle UL-1 Power
I have not been able to compare radios so I have no actual data on this, but I do like the design of the MR3000 receiver which is water resistant and also has 2 antenna inputs in case one loses the signal. Theoretically, 2.4ghz and water don't like each other, so the more signal diversity the better. I also think it is a good idea to run at least one of the antennas up out of the hull as high up as possible to help with water-signal problems.
I ended up using the spectrum dx3S because I wanted model memory (I can run my primary boat and rescue boat on 2 different "channels"), but I also got the dx3E for my son which is a pretty good price.
-Chief
The only 2.4 radio I recall having a problem with water is the Spektrum. A friend of mine had a horrible time with them. They had to re-engineer and come out with a new expensive receiver to make them reliable.
The Futaba and Airtronics and even the little cheapie Tactic have no problems in boats that I am aware of. I have used all three.Mini Cat Racing USA
Way cheaper than fixing my boat when it goes rouge into shore. The JR recievers I used were more than the Spektrums are. Then get onit wet.....ugh. Been there done that.
I've not heard many complaints with the Fasst. If they water proofed their rx's that would be killer. That whole system is pricey though isn't it?
There's always balloons. That's pretty reliable too.Noisy person
