New Radio for expanding fleet.....
  • JMSCARD
    • Mar 2010
    • 4174
    Well I've got a 3pm 2.4ghz and 3 recievers.... a dx3 with 3 recievers.... and a BUNCH of FM radios..
    I am going to keep using the 3pm and the dx3 but I want to get rid of all my fm radios.....
    My question is:
    Is the Tactic 2.4ghz a good radio for my boats? can I hook up (5) recievers to one radio?
    I like the fact that the radio doesnt have all the adjustments that me "sport" running my boats I don't need..... but does it still have good reception even though there is no antenna??? also if I put the reciever in a ballon to protect from the water is that going to cause a problem... again because of the no antenna? thanks for all the help....!
    Tower has a good deal on the tactic right now...
    tower has them for 59.95 and 23.95 each extra reciever... and if I spend $150 I get free ship and $20 off.... so it sounds like a good deal.... $155.75-20= 135.75 total with (5) recievers and free shipping.... not bad heh?
    • 7512
    I'm running 10 boats off of one Tactic (not all at once though).
    No problems with balloons either.
    • JMSCARD
      • Mar 2010
      • 4174
      Hows the range? I like to run em far away sometimes....
        • 7512
        Well I run them mainly on race courses but I have had one where I couldn't tell if it was coming or going,,,,so I suppose thats pretty far. I downgraded from my Spektrum as well. It was a great radio and never had any issues, but I never used all the features and the electronic trims were a bit of a PITA as well.
        Also, the Tactic only needs 4 batteries vs 8 for my Spektrum.
        • sailr
          • Nov 2007
          • 7128
          I have never experienced a range problem with the TACTIC. They work great. Looks like they recently reduced the price from $79.99 to $59.99 for tx/rcvr. You can buy the "Towerhobbies" receiver (exactly the same as tactic, different label) for something like $18.99 I think.
          I have 3 transmitters and 16 receivers. They can be used interchangeably. You just have to bind the rcvr to the tx the first time!
          Mini Cat Racing USA
          www.minicatracingusa.com
          • JMSCARD
            • Mar 2010
            • 4174
            yeah Tower has the tactic radio on sale for $59.95 and the tower brand still at $69.95 so I figured why not go right with the tactic brand.... are you saying I can buy the tower recievers though? as those are $18.95 instead of $23.95.... I'm sold otherwise though.... I am buying one way or another..... I would just buy from steve but the shipping is free to at tower because Ill be spending enough.....
            • JMSCARD
              • Mar 2010
              • 4174
              And yes Doby the electronic trims are a PITA for sure... exactly the reason I want to get out of them....
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5195
                I have a Tactic radio (came with the UL1) and they are a bargain but for a large fleet I would use your Futaba or your Spectrum as they have memory and other features I find useful, just my 2 cents and yes their receivers are expensive and if you have carbon fibre in your hulls I would be leery of a receiver with no external antenna.
                Douggie
                • Jabbo
                  • Jul 2009
                  • 495
                  Good to see all this good feedback because I just ordered a tactic radio from tower today to go along with my new velocity mono.
                    • 9481
                    I use the spray electrical tap on my receiver, flipped my SV two weeks ago, water got into the hull and the receiver was wet, blew it out threw my boat back into the water and it works perfect..
                    • BHChieftain
                      Fast Electric Addict
                      • 2051
                      Note the new spectrum DX3S uses 4 batteries.
                      I'm using that with the MR3000 receiver-- which is my first 2.4ghz setup so I can't really compare with first hand experience, but I do like the MR3000 reciever design which is highly water resistant, and has 2 attennea leads (in case the radio loses touch with one), and one of them is very long so you can get it way up high out of the boat. From what I've read, 2.4GHz and H20 don't really get along that well...
                      I've read some folks losing radio contact with other 2.4 setups, I bet it has to do with how the receivers are mounted-- need to get 'em above the waterline.
                      One additional benefit of the DX3S (or R) is model memory-- I though I would never use this, but I have a primary boat, and a rescue boat. When I use the rescue boat to retrieve the primary boat, I don't want any signals going the the scuttled boat... so this setup eliminates the need for me to carry around a separate radio.
                      -Chief
                      • tomstoys2
                        • 637
                        This is good info. I'm getting ready to pull the trigger on a 2.4ghz system.
                        I have been tempted to pick up a Tactic but having Model Memory is really key to me. I have a ME3000 I picked up a few months ago that I plan on running in a Carbon/Kevlar hull. I just need to pick a transmitter.
                        • Rumdog
                          • 6667
                          The new Traxxas 2.4ghz system is excellent too! I picked up tx/rx new on ebay for 50 bucks. rx is 5 channel with 2 ports for ch.1 It is good if you want to run 2 steering servos. It also has a multifunction knob that can be programmed to control steering and throttle expo, dual rates, and trim. The rx also has a short external antenna.
                          • Rumdog
                            • 6667
                            For about 100 bucks you can get the futaba 2PL that has 10 model memory. That's what I use in my boats mostly.
                            • tiqueman
                              • Jul 2009
                              • 5866
                              Wait a second.. lets go back to Chiefs post... on a 2.4 that has multiple model set ups, are you saying that if your running your primary boat on model one and roll it, model 2 is set up to your rescue rig and it doesn not transmit to moldel one?????? And is this for any 2.4, ie Futaba?
