Help With Futaba 3PM 2.4 MX Transmitter
  • D&D
    • Aug 2009
    • 185
    I'm really new with electric boats and the new equipment today. I thought that I was about ready for a test run within the next couple of days and then I did some final testing.
    First here is my setup Futaba 2.4G MX transmitter hook to a Castle Hydra HV 180 to run a NEU 1515.1Y. I setup the Castle ESC using the Castle Link software and everything went OK there. I tested my throttle at that time and was getting a steady light on the ESC at full throttle. Now in my final test, everything hooked up, when I powered up the receiver and turned on the transmitter the motor began to run immediately. As I pulled the trigger to full throttle, the motor turned off, when I released the trigger the motor ran again, and when I pushed the trigger to the "brake" side the motor rpm increased (apparently full throttle). I'm thinking that I have some setting on the transmitter set incorrectly. Is any one familiar with this setup that could give me some ideas?
  • Chilli
    • 3204
    Dennis did you calibrate the controller to your transmitter?
    Mike Chirillo
    www.capitolrcmodelboats.com
    • knpc
      • 649
      I use the same radio with my hv240 and lv240. I think you need to set the throttle reverse to ON and make sure the throttle epa is at 120%. I would make those changes, then recalibrate the radio to the ESC and you should be good to go.
      I had the same problem until I found out about the throttle reverse.
      Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
      • D&D
        • Aug 2009
        • 185
        OK, the problem seems to be calibrating the transmitter to the ESC. I don't remember reading about that in my Castle instructions or Futuba? I'll look up the throttle reverse "stuff" again, but calibrating??????
        • D&D
          • Aug 2009
          • 185
          Oh yea, there it is under IMPORTANT NOTE: in all red letters "CALIBRATION", duh!
          • knpc
            • 649
            3.0 Calibrating the HYDRA™ to YOUR transmitter:
            IMPORTANT NOTE: Calibration is required for the very first use of the
            HYDRA™ or whenever used with a new/different transmitter.
            The HYDRA™ contains a throttle calibration feature that you'll want to use the first
            time you power it up with a new/different transmitter. Performing this exercise will
            teach the controller how your transmitter works.
            • Disconnect battery
            • Hold full throttle on your transmitter
            • Connect battery
            • HYDRA HV™ flashes LED and rings once
            • Wait 2 seconds
            • HYDRA HV™ flashes LED and rings 4 times indicating full throttle
            measured
            • HYDRA HV™ flashes LED while beeping, indicating it's time to push full
            brake
            • Push full brake
            • Wait 1 second
            • HYDRA HV™ flashes LED and rings 4 times indicating full brake
            measured
            • HYDRA HV™ flashes LED while beeping indicating its time for neutral
            • Relax trigger to neutral (center)
            • Wait 1 second
            • HYDRA HV™ flashes LED and rings 4 times indicating neutral measured
            • Wait for 1 second
            • HYDRA HV™ will flash LED and ring twice indicating that it is armed
            • D&D
              • Aug 2009
              • 185
              ESC armed and ready. Thanks all!
              • Chilli
                • 3204
                Ask me how I knew it was the calibration Dennis....
                Mike Chirillo
