REAL BAD DAY!! Tactic 2.4ghz Radio Contact Loss!!
  • Shooter
    Team Mojo
    • Jun 2009
    • 2520
    Well, this video isn't pretty. My hydro became a submarine....note the huge plume of water bubbling up! Not sure what the cause is at this point. Seems that I hooked and dove in. When I tried to restart, she went under and I lost complete radio contact. Sure enough, it continued at FULL throttle straight down. For some reason my flexshaft broke into TWO!! and the stuffing tube was mutilated.
    1. Anyone had this happen with 2.4ghz?? Not sure how well these radios work once you are under water!
    2. My stuffing tube is a MESS. Any ideas on how to remove it?
    Thanks guys.
    Video of the incident (amazingly, the wife was videoing.....)
  • crabstick
    • 954
    water + receiver = bound for failure.
    Get some DP270 and waterproof the next one.
    Matt.
    www.rcboats.co.nz
    • Shooter
      Team Mojo
      • Jun 2009
      • 2520
      The receiver (as well as the rest of the inside) was BONE DRY. Not a single drop of water. This pickle hull seals very well.
      • crabstick
        • 954
        sorry, read your post wrong I thought she got wet. I have heard of a couple of issues with those tactic radios.. maybe it doesn't get very good signal under water?
        Matt.
        www.rcboats.co.nz
        • bwells
          • Jan 2009
          • 842
          Shoot howdy, I have 2 Tactic 2.4 Gig setups. Are you sure the radio drove it down? Hard to see what happened by the vid but it sure looked like it was running good
          • Shooter
            Team Mojo
            • Jun 2009
            • 2520
            Once she got a little under, the radio gave up and I lost control. It's almost like the signal couldn't penetrate beneath the surface. Went to full throttle and headed further under. I have several of the tactic radios as well and I agree....they have all been fine until this incident.
            • Rumdog
              • 6453
              What speed control?
              • Shooter
                Team Mojo
                • Jun 2009
                • 2520
                All the electronics are stock UL-1 (ESC, motor, etc...)
                • Rumdog
                  • 6453
                  I ask because generally the speed control should cut the throttle if signal is lost.
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2520
                    Good point Rumdog. I wonder why it continued at full throttle. Maybe it's a radio problem. Could the Aluminum boat I was in have anything to do with it?
                    • Doug Smock
                      • 5264
                      I haven't tested the UL-1 control but I know that the Castle Hydra controls will hold their last command for approx. six seconds when there is a signal loss.
                      Six seconds is a Looooooooooooong time.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • Rumdog
                        • 6453
                        Wow! I never would have thought that!
                        • Rumdog
                          • 6453
                          I'd better test my esc's, stat!
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2520
                            I will give it a test tomorrow. I would hope that it returns to neutral if the signal is lost.
                            • Doug Smock
                              • 5264
                              [QUOTE=Shooter;177407]
                              QUOTE]
                              Is that a Vac-U-pickle, is the stuffing tube epoxied in?
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
