Motor KV?
  • M.M.
    • 271
    Motor KV?
    If i purchased a hacker b50 8l for this boat:
    http://cgi.ebay.com/25-deep-vee-ARTR...3A1%7C294%3A30
    Can i run it on 2s and 3s? With a turnigy 120A ESC
  • Diegoboy
    • Mar 2007
    • 7443
    Yes.
    • M.M.
      • 271
      Thanks.
      What about one of these motors?
      • Diegoboy
        • Mar 2007
        • 7443
        That motor kV is too low for 2S or 3S
        • M.M.
          • 271
          What would be better for KV? because i have two 3s 2200 25c lipos that i run in parellel, and i have 2 2s 5000 20c lipos that i can run in series or parrellel. So what is better high or low KV? I would prefer to run the 2s in parellel to get 10000mah. Then ill have the 3s in parellel for just messing around.
          So around what is a good KV for 2 and 3s?
          • TRUCKPULL
            • 3293
            The 2880 kv motor it comes with would be OK (about max RPM for a mono) on 3S.
            I would not run it on 4S.
            It would also be OK as a Sport boat on 2S
            Larry
            • ozzie-crawl
              • Sep 2008
              • 2943
              with your 2s 5000 in series run either a ammo 2300 x440 prop see you around 45mph. if more speed is wanted try a 8xl x640 prop
              • M.M.
                • 271
                So it would be better to run a lower Kv motor with higher voltage, rather than lowering the voltage with a higher Kv motor?
                • domwilson
                  • 4411
                  This thread has a lot of good info. http://forums.offshoreelectrics.com/...read.php?t=271
                  Government Moto:
                  • ozzie-crawl
                    • Sep 2008
                    • 2943
                    generally yes. i have seen a lot off people try and run these on high kv 380 or cheap 540s motors and usally all they do is pull high amps
                    i look at it this way the bigger xl motors can pull more amps but they have more power so they can spin the same size prop a lot easier so they dont pull more amps. my 25" mono runs a ammo 2300 on 4s with a x440 and i only run a 45amp esc. the esc and batteries you have should be enough for a 8xl
                    i would start with a x440 and go from there
                    • domwilson
                      • 4411
                      Agreed. Someone once told me, a "S" motor should be considered like a 4 cyl. An "L" like a 6 cyl. and a "XL" like a 8 cyl. At least as far as the chinese 2 pole motors go. Take a look at post #19 in my previous post for general guidelines.
                      Government Moto:
                      • ozzie-crawl
                        • Sep 2008
                        • 2943
                        i like that analogy now with the 580l we also have the supercharged v8
                        • M.M.
                          • 271
                          [quote]with your 2s 5000 in series run either a ammo 2300 x440 prop see you around 45mph. if more speed is wanted try a 8xl x640 prop [quote]
                          Well i got an 8xl coming my way, now what can i do for the prop situation? Because i beleive it is an 1/8 shaft. Can i just use a little shim? That way i can run the 3/16 x640
                          • domwilson
                            • 4411
                            [QUOTE=M.M.;102968][quote]with your 2s 5000 in series run either a ammo 2300 x440 prop see you around 45mph. if more speed is wanted try a 8xl x640 prop
                            Yes. You can put a small piece of k&s tubing in the prop to shim it up http://www.offshoreelectrics.com/inf...propellers.php
                            Government Moto:
                            • M.M.
                              • 271
                              Ok, thanks
                              Now i need ozzie crawl to check out this thread and make sure an x640 is the right prop?
