TP 5680 motor mount for 6 bolt pattern, 5 inch rails
  • voepel
    • 56
    Does anyone know of other 6 bolt pattern motor mount brackets besides the one OSE sells? I am switching out motors from a leopard 56110 4 bolt pattern to TP 5680 6 bolt pattern motor mount.
    Thanks, Steve
    • 4340
    It's the only one I found. You could try Bonzi Sports and see what they use.
    • voepel
      • 56
      Had no luck with calling TP or Bonzi. It looks like everything made now outside of the quick change OSE Steve has is carbon fiber glue mounting. I was trying to find the motor end bracket only. Not the old school I have. Steve mentioned I may be able to have two of the 4 bolt pattern match up to the 6 bolt pattern, so that may suffice, but not ideal. IMG_5012.jpg IMG_5013.jpg
      See pictures.
      Thanks for looking.
      Steve
      • Peter A
        • 1622
        Redrill the mount for six bolts?
          • 4340
          Ok, I'll bite, what's wrong with the 6bolt TFL mount that OSE sells?
          • Bande1
            • Mar 2023
            • 678
            cut the center section of the rail mount out, make a new 6 bolt center portion. drill and tap new center section and bolt it to the old mount tabs. amazon has 1/8 and 1/4 inch aluminum sheeting on black friday sale.
            • voepel
              • 56
              Steve from OSE said that you could use a 6 bolt pattern on a 4 bolt mount. I tried thar and I was able to use two of the 4 holes diagonally which coupled with the back motor mount support seems to suffice. After all the searching I did, I have no idea who made the originally 4 bolt mount for the 5 inch rails, but it seems times have changed for what is offered now.
              Thanks for the help, Steve
