Soldering connectors to motor wires.
  • Bushmen77
    • May 2016
    • 82
    I got these motor connectors that have 2 holes like 3mm up off the bottom in them. When I solder the motor wires into them all I get is a tiny bit of the wire in a few mm of solder. From the holes up to the top of the connector there no solder at all. This does not seam right.
    I would think you want the bullet full of solder is that correct?
    I just read about wrapping copper wire but don?t know details how to do, never heard of it.
    Correct me if wrong ?
    1. Tin motor wire .
    2. Wrap copper wire around tined motor wire to size on ID a of connector.
    3. Tin copper wire on motor wire first.
    4. Put motor wire with copper wire wrapped not tined into connector heat fill with solder.
    Is this whole thing wrong or parts ?
    Does the copper wire melt or just serve to fill the void?
    Thx
  • zooma
    Local club FE racer
    • May 2014
    • 653
    That's what I do. The copper wire wrap fills the void, and should handle heat better.
    Ron - The Villages, FL
    • Bushmen77
      • May 2016
      • 82
      Ok will try that next . Thx
