Question about motor timing
  • ezhitz
    • Aug 2009
    • 466
    I was wondering what the effect of 0 timing used on a wye motor? Why I ask is that when I asked TP motors about a motor I
    had if it was a D or Y wind they said it was a D but there engineers say to use 0 on all there motors. Now I know when you increase the
    timing on a d wind you create more heat with no gain but what happens when you run a wye wind on 0.
    :canada
    • 4340
    I've never understood why TP says that. I've heard other people report the same response from them. I run my TP Y wind motors on 11-15* timing depending on the ESC.
      Years ago I asked Steve Neu what timing was best for Y and Delta winds. He told me 8*-15* was a good range for Y motors, and Delta motors liked 0-4.8*. Maybe he knows something about BL motors...
      I suspect that some sources specify low timing thinking to protect their customers from overheating an over-propped motor. Since most of our motors were originally designed for planes - which usually have much lower amp draw - lower timing may work better for them. Too low timing in a high amp Y-powered boat will slow it down and overheat things.
      • ezhitz
        • Aug 2009
        • 466
        Thanks for the reply. I agree about Steve Neu and his knowledge about bl motors.
        That’s what I wondered about the y wind motors.
        :canada
        • ezhitz
          • Aug 2009
          • 466
          Today I tried increasing the timing from 0 to 12 degrees noticed a drop in motor temp from155 to 127 with the same prop.
          :canada
            Cool!
            • 785boats
              Wet Track Racing
              • 3423
              I assume, that is with a Y wind motor?
              • ezhitz
                • Aug 2009
                • 466
                That’s what I assume to even though I was told it was a d wind. I testing I have been keeping my run times to around 1 1/2 minutes on my timer prop ranged from a x642 - abc 1815 and I thought the heat at 0 timing seemed I little to warm.
                :canada
                • TRUCKPULL
                  • 3293
                  What motor is it??
                  Larry
                  • ezhitz
                    • Aug 2009
                    • 466
                    Hey Larry hope you’re doing better. The motor is a TP 4060 2200kv
                    :canada
                    • TRUCKPULL
                      • 3293
                      Jack - TP does not make a 4060 any where near a 2200kv
                      They do have a 4070 - 2250 kv - 2Y - -- 40mm X 100mm
                      This may be why is runs better at the higher timing.
                      Larry
                      • ezhitz
                        • Aug 2009
                        • 466
                        I order it special and it wasn’t marked on the box if was a d or y wind and when I asked was told they recommend 0 timing on all their motors.
                        :canada
                        • TRUCKPULL
                          • 3293
                          Ok with it being a custom wind from the factory, I would say with the results that you have found by raising the timing. it is a "Y" wind.
                          Larry
                          • scrambow
                            • Jan 2021
                            • 15
                            Newbie question: Concerning the wind of a motor, how can we identify the wind type? I have the ACE Ripper IBL40/20 2000KV motor and can't find any specs on the wind type. My end game is getting the timing set correctly in the Sea King 180A ESC I am using.
                            Thanks all
                            Jim
                            • T.S.Davis
                              • 6266
                              Hey Larry hope you?re doing better. The motor is a TP 4060 2200kv
                              Somebody was peeking.
                              Noisy person
