How to Identify a TP Power motor
  • Crash
    • Oct 2015
    • 313
    Is there anyway to identify a TP motors KV?
    its 92mm long
    8mm shaft
  • Crash
    • Oct 2015
    • 313
    so I did a bench test to see if I could get a real time rpm measurement
    with the prop and flex shaft disconnected from the motor I am only getting 17900 rpm on 5S that seems really low unless this motor is a 1050kv its suppose to be a 1650kv
    did I do the math rite?
    • Prodrvr
      • Jul 2015
      • 701
      It should be written on the can at the wire end. That's how mine are.
      • Prodrvr
        • Jul 2015
        • 701
        1050Kv on 5s should be 19,425 rpm.
          I get closer to 18,200 for the 1050 but then that would be loaded with good packs. Most of my TP’s do have a KV on them but it is just a small sticker. Perhaps one of those little Watt meters would help
            Do you have a voltage for that exact 17,900 time frame? 17,900 divided by voltage should give KV. I assume you are using the ESC to get data?
            And if it is 1650 I’d be using like a 3s pack for full throttle.
              • 4338
              The kV is written in pen on a sticker near the end bell and is pretty useless after about a season. I take the stickers off. Which reminds me, I want to start engraving that kV number into the end cap on mine.
              • donhuff
                • Dec 2014
                • 561
                Here is the setup that I use to check the actual Kv.
                AmpDaddy
                don huff
                • golfito
                  • Sep 2011
                  • 302
                  I am very interested.
                  I ask, disarming the motor to determine if it is a motor with configuration Y (star) or with configuration D (delta). And then you get the internal resistance between two stator terminals. (using the method of circulating a current through the winding under test) R = V / A. Obtain the internal resistance in that way and then compare that value with the manufacturer's RI tables. Can it be viable?
                  • golfito
                    • Sep 2011
                    • 302
                    https://www.wattflyer.com/forums/showthread.php?t=50740
                    If you follow Bruce at RC Model Reviews on youtube, you might have seen this before: I have 4 motors I bought at Flite Fest and when I went down in the beans and forgot to disarm I smoked the ESCs (actually my quad caught fire, it was awesome!) Anyway, I replaced the ESCs at home and fired...
                    • Speedfreek
                      • Apr 2018
                      • 276
                      Originally posted by golfito View Post
                      [ATTACH=CONFIG]162243[/ATTACH]
                      [ATTACH=CONFIG]162242[/ATTACH]
                      [ATTACH=CONFIG]162244[/ATTACH]
                      https://forum.flitetest.com/index.ph...-motors.20346/
                      Stupid question for you, lets say you can have a identical kv in Y and D which one would be better ?
                      MYSTIC 138 119 MPH so far
                      • golfito
                        • Sep 2011
                        • 302
                        I think I understand. Excuse my English.
                        I am a beginner in these subjects. And for what I am reading:
                        I think you should not worry about the type of configuration D or Y to choose an engine to the same KV. Both are very effecient. But you should know what kind of time or progress to use in each type of configuration.
                        • Speedfreek
                          • Apr 2018
                          • 276
                          Ok thanks, so your saying just chose what kv you want and don't worry about if it is a Y or D wind, yes ?
                          • golfito
                            • Sep 2011
                            • 302
                            Yes.
                            I choose the kv that I consider appropriate.
                            I only take precautions when choosing the timing or progress.
                            I have 7D engines where I use 0 timing. And other 1.5Y engines where I use 11.25 timing.
                            Perhaps the most advanced runners can notice some difference between the Y and the D engines at the same KV number.
                            • Speedfreek
                              • Apr 2018
                              • 276
                              Yes.
                              Thanks for your input
                              Sorry for the hijacking
