Motor length vs amp draw
  • Alfa Spirit
    • 2183
    A brushless motor NEU 1512 have the same efficiency than a NEU 1521, the value is high, more than 92% .
    • gearhd48
      • May 2015
      • 139
      Back in the old drag racing days, they used to say " there's no replacement for displacement" . Now days it's hard to say!
      SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.
      • bhorowitz
        • Jun 2015
        • 109
        Maybe I'm mistaken, but I always thought if you double the voltage, you cut the amperage in half.
        • Alfa Spirit
          • 2183
          That' s right,
          P (watts) = U (volts) x I (amperes)
          • Speed3
            • Mar 2017
            • 371
            If you double voltage you cut the ampage in half if you was making a 1000 watts at 10v
            And you want to make a 1000 watts at 20v then you cut the ampage in half.
            That is not the case if you have an electric boat and using the same motor and same prop, then decide to double the voltage.
            • 785boats
              Wet Track Racing
              • 3423
              You beat me to it Speed.
              Totally correct.
              If you reduce the kv of the motor to turn the prop at the same RPM that it was doing on the lower voltage, THEN you will reduce the amp draw with the higher voltage.
              If you leave the kv of the motor & the prop size the same, you will more than double your amp draw when you double the voltage because the prop will be spinning at twice the revs increasing the load on the motor.
              • bhorowitz
                • Jun 2015
                • 109
                Thanks for that explanation.
                • NativePaul
                  Greased Weasel
                  • 2770
                  What were the voltages? Amp draw vs RPM means nothing without a voltage alongside it to indicate the power? It obvously wasnt consistant voltage as you have more RPM with more load on the Leopard, and RPM will drop with increased load if the voltage is constant.
                  You are also comparing a RTR motor with an aftermarket motor, to me your data says that a Leopard is more efficient than an Aquacraft, which is no surprise. Compare the Leopard 4092 against a Leopard 3360 if you want to draw a conclusion about the efficiency of motor sizes.
                  • Alfa Spirit
                    • 2183
                    This is correct with same brand and same range motors.
                    If you compare a poor Leopard and a NEU Motor, efficiency is not the same .
                    • Speed3
                      • Mar 2017
                      • 371
                      The purpose of the data log was to show that size of motor does not necessarily increase amp draw.
                      And yes the leopard is holding the rpm better with the same load.
                      The voltage with the k42 is 7.4 leopard and 7.4 aquacraft.
                      • NativePaul
                        Greased Weasel
                        • 2770
                        It is the Leopard I was talking about, it is holding RPM better than itself!
                        "13389 rpm @ 24.6 amps on 2s with the k42.
                        13467 rpm @ 30.4 amps on 2s with the x642."
                        7.4 is the nominal voltage of the battery, I am talking about the actual voltage at the time of the amp and RPM readings, which is needed to calculate input power and compare efficiencies. It's not possible for the motor to provide the results above at the same voltage, the X642 reading was taken at a higher voltage.
                        • Alfa Spirit
                          • 2183
                          Use silicone gun oïl for the ball bearings ... LoL
                          • Speed3
                            • Mar 2017
                            • 371
                            The 7.4v is the voltage for the k42.
                            The 642 was 7.7v with the leopard but I think that voltage was a little high because how can the voltage drop to 7.4v at 24.6 Amps.
                            And the same pack give 7.7v at 30.4 amps without even charging the battery.
                            • Speed3
                              • Mar 2017
                              • 371
                              My cells have very low internal resistance.
                              I did a datalogged at 100amps with a 3s. And the voltage drop is .4volts.
                              That is if you start at 12v it drops to 11.6v at 100 amps.
                              • NativePaul
                                Greased Weasel
                                • 2770
                                Either you measured the k42 later in the discharge cycle when the battery had less juice in it, or your figures are off. What about the voltages for the Aquacraft tests?
