Any chance the motor mounting screws were a bit too long?
Burnt out motor
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
A 4092 have enough torque to break the solder joint which holds the flex cable to the solid metal piece which holds the prop.
Check the shalf good and see if the solid part holding the prop is holding firmly to the flex cable.
Because that prop you mention is enough load to cause a breakdown like this.
Hi Gents
prop was defenetely the cause of the burn out. 69mm prop way to big.
As for the GoolRC 160A ESC, programming is done via transmitter and counting Beeps
No programming card required.
https://hobbyking.com/media/file/606792873X68524X7.pdf
After all the running around and money spend on program cards and 2 still on order, wish i had found this earlier.
Solved the programming issue
i hope this helps all who in future use the GoolRC 160A ESC
