TP Motor Kv unknown
  • CraigP
    • May 2017
    • 1464
    Yeah, I think so. Start with a small prop and check temps. Or use a data logger... I only data log. But temps should be enough. Looking for motor temps around 140-150, ESC temps around 130-140.. if an ESC comes up for sale cheap in the 220-250a range, might want to shag it. So you race gas? Do you have a nitro boat? I started in nitro hydros, a long time ago... I'm loving FE, being an electrical engineer. LiPo batteries make a big difference, but miss the run times and noise of nitro sometimes!
    • properchopper
      rcgoatbuild@snotmail.com
      • 7708
      Originally posted by Insanity Plea View Post
      I received a TP 4060 V1 motor as part of a package deal, it was assumed to be a 2040kv but I don't see that as a listed kv. The numbers are not on the silver label like normal. Any way to tell the kv?
      Here's a fairly simple/accurate way to find out KV on a motor already installed in boat. (Can rig a motor-only bench tester if need be):
      Step One : Get your hands on one of these *
      Step Two ::
      Plug everything in on boat and arm
      On propshaft install a spare servo arm (or whatever) with supplied reflective tape stuck on for reading.
      Install a volt reading device on the battery.
      Step Three :
      Aim tach at reflecto-thingie with one hand and push button
      Pin xmitter WFO with other hand
      Take picture for thread with third hand ()
      Battery V reading at WFO ; (battery started at storage V but doesn't matter for this test)
      RPM reading at WFO :
      Step Four :
      Divide RPM 31,500 by WFO V 14.67 - you get a bench calculated KV of 2161.97 . Stated KV from TP Power is 2200. Pretty slick
      *Tach won't break the Bank :
      • CraigP
        • May 2017
        • 1464
        Nice! Mikey likes it!
        • Insanity Plea
          • May 2017
          • 562
          Thanks chopper, and everyone else for the info. After I get this busted hull figured out I'll revisit the kv issue. I know I can just run a couple different S batteries, but if it works good I'm going to want to know what I have.
          IMPBA 20583
