Timing for a TP 4060 1950kv 5D
  • RuntheraceAMC
    • Sep 2016
    • 222
    What timing should I set?
  • TRUCKPULL
    • 3293
    For "D" wind motors = 0 or 1 Degrees Timing, anything more just causes heat.
    They are not like a "Y" wind .
    Larry
    • RuntheraceAMC
      • Sep 2016
      • 222
      Is there any reason to do 1 over 0? Is there a difference in performance?
      • TRUCKPULL
        • 3293
        I set my "D"s at 1 Degree, just enough to stop cogging.
        Timing has NO effect on performance on a "D" wind, it just causes heat.
        Larry
        • RuntheraceAMC
          • Sep 2016
          • 222
          Gotcha. Thanks
          • zooma
            Local club FE racer
            • May 2014
            • 653
            Larry
            Want to know more about cogging. Sounds like a learning experience.
            Related question: Would an "automatic" timing setting like on a Swordfish be trustworthy or harmful on a D?
            Ron - The Villages, FL
            • TRUCKPULL
              • 3293
              Cogging is when a motor shudders on startup. It doesn't know if it wants to run forward or backward.
              I have heard that Swordfish like the automatic setting for "Y" motors, but I don't know about "D"'s (I don't run them)
              Larry
              • RuntheraceAMC
                • Sep 2016
                • 222
                I can only select 0 or 3.75 on my esc. What would you suggest?
                • TRUCKPULL
                  • 3293
                  I would say "0" If it gives you major problems then try 3.75 but watch for heat.
                  Larry
                  • RuntheraceAMC
                    • Sep 2016
                    • 222
                    Set it to zero it it seems to be running Smooth
                      The timing of a BL motor cannot be a single value, the motor wouldn't work nearly as well if the timing was static like an old skool brushed motor. With decent quality ESCs it doesn't matter if you choose "0" or "5" degrees, the ESC decides what is the best timing based on feedback from the motor as the load changes. The timing you input only defines a timing range from which the motor chooses the right timing. You may set "4" but the ESC may actually use "8" simply because that is what the motor really needs at a particular moment. You are fooling yourself if you think there is any real difference between settings "0" and "1"...
