lehner 2240/5 help
  • Jcarlton
    • 521
    lehner 2240/5 help
    hey guys got a awesome deal on a lehner 2240/5 hi amp 2960kv loaded . was wondering if a turnigy 180v3 can handle that motor on 6s ? was thinking about installing on a mg 29 (prolly overkill) ! any ideas or other input would be appreciated !
  • Todd Fleury
    • 469
    No way will that esc hold up.
    • Todd Fleury
      • 469
      I run a 2250 - 2603kv lehner with a 250 amp esc and I still peak the amps on 4s
      • Jcarlton
        • 521
        what esc would you suggest ?
        • Todd Fleury
          • 469
          That all depends on what you want to spend. But you would need to get something 250+
          • Jcarlton
            • 521
            what are you running todd ?
            • T.S.Davis
              • 6266
              You'll need more than 250. That's way too many kV for 6s. It's a lot for 4s.
              Noisy person
              • Jcarlton
                • 521
                so whats the best setup in your opinion ? what esc and what batery size ? im new to these lehner motors . was going to run the lehner in a mg 29 with a octurra x438 prop any thoughts ?
                • Todd Fleury
                  • 469
                  I run an MGM 250
                  • StevenBryant
                    • Nov 2012
                    • 366
                    You motor would be a good 3s motor maybe 4s but that's gonna be a hot setup. A good speed controller is the MGM 280-26
                    • photohoward1
                      • 1781
                      6s? That motor it to much for 4s. POOF.
                      • Jcarlton
                        • 521
                        great thanks for the input fellas !!
                        • Jcarlton
                          • 521
                          ok guys got a good deal on a 200a swordfish pro+ . can this controller handle the lehner 2240/5 on 4s 70c lipo with a 38mm prop on a 36 in cat .
                          • Todd Fleury
                            • 469
                            That motor is 3255 kv unloaded. That esc will not be able to handle the amp.
                            • Jcarlton
                              • 521
                              loaded its 2960 kv whats the difference ? and how many amps do you think it will pull on the above setup ?
