timing for leo 4074 1800kv 4.5D
  • RuntheraceAMC
    • Sep 2016
    • 222
    I just ordered a leo 4074 1800kv 4.5D for my blackjack 24. Running it on 5s with a Rader 150a and 40-42MM props. What timing should I use for this set up?
  • martin
    • 2881
    D wind motors 0-5 degrees, in the case of the Raider you can use 0 or 3.75 degrees.
    • RuntheraceAMC
      • Sep 2016
      • 222
      Martin,
      What timing should be used for a Leo 4092 1730 kv
      • TRUCKPULL
        • 3293
        Originally posted by RuntheraceAMC View Post
        Martin,
        That motor is also a "D" wind, so same as above. 0 to 5 Degrees
        Higher timing on a "D" motor on causes heat with no change in RPM .
        I use o timing on all "D" motors.
        Larry
        • RuntheraceAMC
          • Sep 2016
          • 222
          Thank you
