Different between 6 pole and 4 pole
  • langevn
    • Mar 2015
    • 214
    Hello everyone looking for some info on these 2 motor and also how pole are calculated
    1850kv 6 pole vs 2150kv 4 pole looking simple answer
    Thank you
    Sent from my SGH-I337M using Tapatalk
  • StevenBryant
    • Nov 2012
    • 366
    A bit more info would help, manufacturer, model, Inrunner out runner etc? Number of poles referees to the number of poles on the motor, 2,4,6 etc
      "Poles" refers to the number of magnets in the motor. A 4-pole inrunner has 4 magnet segments on the internal rotor. A 10-pole outrunner has 10 magnet segments on the external rotor. More detailed information can be found here:
      http://www.radiocontrolinfo.com/brushless-motor-poles/
      There is no one "best" type, it depends on the use for the motor. High torque/lower rpm applications are well served by high pole count outrunners. High rpm applications are well served by 2 and 4 pole motors. For most FE sport running, the 4 or 6 pole motors work great.
      • langevn
        • Mar 2015
        • 214
        Ok what is the difference between these two motor 4 pole 2150kv and 6 pole 1850kv both are from aquacraft super vee ??
        • langevn
          • Mar 2015
          • 214
          And thank you for all help that is coming to
            There never was a 2150 Kv motor in a stock SuperVee so we still know nothing about it. But if the motors are of the same quality and size, the pole count means nothing. It is the Kv which matters, the 2150 will require a smaller prop and will stress the ESC more than the 1800 will. Since the SuperVee is hull limited in speed, there is no real advantage to the 2150 motor since the 1800 will drive the boat faster than it can safely handle.
            • langevn
              • Mar 2015
              • 214
              This is for me this is a friend that blew is 1850kv and he has a new one but the motor is a 2150kv
                • 4340
                following up on this topic, what about two Dynamite 2000kv motors, one 4 pole, one 6 pole? Aside from physical size, does the 6 pole offer a performance increase over the 4 pole, perhaps an increase in torque?
                • TRUCKPULL
                  • 3293
                  Ryan
                  6P is a 36mm X 62mm
                  2000KV
                  25V max.
                  4P is a 36mm X 50mm
                  2400KV not 2000KV
                  12.6V max
                  The larger motor is better all around, More Watts, More Torque
                  Unless your hull is very small, then stay with the 36/50
                  Larry
                    • 4340
                    Thanks Larry. Just trying to decipher the differences between given motors based on the printed specs.
                    • MarkF
                      dinogylipos.com
                      • Mar 2008
                      • 988
                      Yes, 6 pole has more torque than 4 pole with all being equal.
                      Mark
