T.P. motor
  • urbs00007
    • Jun 2011
    • 857
    T.P. motor
    converting a nitro rigger to electric for sport running. its 42 " overall and with a 90 nitro motor and 1667 prop it ran 82 mph. I have a castle 240 and numerous 3-s 5000 65c packs. also have neu 1527 1 D, but think its too many kv's. what T.P. motor would you guys recommend? looking for mid 70's speed and decent run-times. thanks
  • StevenBryant
    • Nov 2012
    • 366
    Which rigger are you going to
    Use?
    I converted to and Eagle 45 SG to a Q hydro, it was a very tight build with several mods needed to the hull to take all the electrics and get them into the right place. I run 6s 5000mah cells and I get 8 to 9 laps max out.
    The build was a pig and had taken time to get setup however it is now running really well and handles choppy water really well
    • urbs00007
      • Jun 2011
      • 857
      Use?
      hi, i have built a 45 outrigger with 6-s 4082 1600 kv, this boat is a 90 size rigger. dont know if i can run it on 6-s, but would like to. here is a pic with a 4082 for size comparison. 001.jpg
      • StevenBryant
        • Nov 2012
        • 366
        Now that's a big rigger, you will probably want a 56mm can to power that, and a lot of mah.
        • urbs00007
          • Jun 2011
          • 857
          if i want to run my castle 240, what t.p 56 series motor and how many cells?
            Max voltage for the Castle depends on the exact model but is probably 8S. That's not exactly an outrigger, closer to a sport hydro...meaning heavy. Depending on your performance expectations a 1530-sized motor can work, but so can a 56xx. The latter may work better due to the larger prop it can swing.
            • urbs00007
              • Jun 2011
              • 857
              t.p. motor
              thanks jay. this boat, although a little on the heavy side, will run light on the water because of it's design. I'm looking for around 70 mph sport running with decent run-time. on 8-s with the castle 240 (mamba xl2 water-cooled ) which 56 motor do you recommend ? thanks, john
              • flraptor07
                • Aug 2013
                • 2451
                I'd probably go with the TP 5670 5D 1320kv on 8s it'll be turning about 39,000rpm max, just a hair on the hot side but should be fast propped right.
                • urbs00007
                  • Jun 2011
                  • 857
                  tp motor
                  thanks, any idea on possible run time?
                  • TRUCKPULL
                    • 3293
                    1 mill lap
                    6 lap race
                    Bring it in
                    Larry
                      Sometimes you have to do 8 laps if CD instructs you to stay on the course. I'm not sure if I'm referring to NAMBA or IMPBA.
                      • JohnZ
                        • 267
                        I wish some of these motor manufacturers would include more info with their motors. How many cells? RPM max? Maybe even a few prop recommendations would be helpful.
                        • grsboats
                          • 1011
                          Manufacturers use to set max voltage and rpm for their motors that doesn't mean you have to use it...prop recommendation is something that I would like to hear from them.....forget it..here is the right place to get the right info for what we need.Gill
                          GO FAST AND TURN RIGHT !
                          www.grsboats.com.br
