Timing for Dynamite 2000kv 4 pole motor
  • DBJr
    • 109
    Just installed a new Hobbywing 60A V3 ESC in my ProBoat Blackjack 24 and was just wondering if anyone knew if this is either a D or Y wind motor.
    This is the Dynamite 3650 2000kv 4 pole motor. I set the timing at 7.5 degrees, down a bit from the default setting of 15 degrees. I'll run a bit and monitor motor temps.
    This motor ran HOT, about 145-150 degrees with the stock 30A ESC. Not sure what they had the timing set at.
    I plan to run this with an Octura X640 prop so we'll see what happens.
    Current boats
    Aquacraft Cajun Commander, Aquacraft Mini Alligator Tours - brushless, ProBoat Blackjack 9, ProBoat Impulse 9, ProBoat Recoil 17, ProBoat Blackjack 24, ProBoat Shockwave 26 BL V3
  • DBJr
    • 109
    Just heard back from Horizon. This is a Delta or D wind motor.
    I've since reset the timing to 3.75. We'll see what that does. The last run I had the timing at 7.5 and the motor still ran hot. Not to mention my negative lead de-soldered itself but I have since fixed that. Must have been a cold solder joint. I made sure to hold the heat on a bit longer.
    Current boats
    • TRUCKPULL
      • 3293
      "D" wind motors -
      I was told 0 to 2 degrees Max.
      I set all my "D"'s to 1 degree, just enough to stop cogging.
      Timing on a "D" wind just causes heat, NO change in RPM.
      Larry
      • DBJr
        • 109
        Originally posted by TRUCKPULL View Post
        "D" wind motors -
        Larry
        Thanks for the reply Larry
        With the Seaking V3 ESC, the timing in the low range is either 0 or 3.75 which is where I am currently. I'll drop the timing to 0 if the 3.75 setting gets things hot.
        Current boats
        • TRUCKPULL
          • 3293
          I would say 0 would better then 3.75 on a "D"
          Larry
          • DBJr
            • 109
            Sounds good. I'll give the 0 setting a try.
            Current boats
            • TRUCKPULL
              • 3293
              Donald
              Depending where you are in Florida,
              You should check out the
              West Florida Model boat club, Sarasota, FL.
              Larry
              • DBJr
                • 109
                Donald
                Larry
                Hey Larry
                I'm in Fort Myers, about an hour and a half away but if I ever get up that way, I'll definitely check this out.
                Thanks for the invite.
                Current boats
                • TRUCKPULL
                  • 3293
                  A couple of the guys from our club are from down that way.
                  They run at a pond behind the Publix, on the corner of Pine Island rd. and Burnt Store rd.
                  Larry
                  • DBJr
                    • 109
                    Larry
                    I know where that is. Never been there but I have seen it.
                    Also, turns out the 0* setting for the timing was the ticket. Everything came back much cooler, the motor was warm to the touch but not burning hot as before. The ESC was just barely warm as the wires, connectors and the 50C 3S lipo that I run in this boat and the Octura X640 prop works very well on this boat.
                    If there was a decrease in motor RPM by lowering the timing down to the minimum, I couldn't detect it. Thank you very much for the tip. I'll definitely keep this in mind for D wind brushless motors.
                    Current boats
                    • TRUCKPULL
                      • 3293
                      RPM is NOT effected on a "D" wind when timing is changed.
                      "Y" wind is a different story- increase timing = more RPM with less torque.
                      Larry
                      • DBJr
                        • 109
                        Larry
                        True
                        I'll have to pull out my temp gun the next time I run but before I was getting temps of about 145-150*F. The motor literature mentioned NOT to exceed 160*F so that was cutting it close.
                        Not to mention the Seaking ESC had a default timing of 15 degrees. Can't imagine why.
                        Current boats
                        • zooma
                          Local club FE racer
                          • May 2014
                          • 653
                          Larry
                          So, what's going on with a D wind when the timing gets more advanced? No more power, just more heat? What about the difference between 0 deg and 3.75?
                          Ron - The Villages, FL
                          • TRUCKPULL
                            • 3293
                            More timing more heat.
                            Larry
                            • DBJr
                              • 109
                              Not to mention the Seaking ESC goes up to a max timing of 26.25 degrees. That would probably smoke any motor.
                              I was very satisfied with the temps while running the timing at 0. I don't plan to change it unless I was to install a Y wind motor at some point.
                              Current boats
