timing for 4074 2200kv
  • langevn
    • Mar 2015
    • 214
    hi looking for the timing for a leopard 4074 2200kv running 2 x 2s 6200 mha 50c and prop m645 the boat is tthe insane fe 30
    Use low timing on D-wind motors.
      that is a Y wind motor Fluid.
      • rickwess
        • Apr 2013
        • 777
        Auto (if your ESC supports it)
        • martin
          • 2881
          It is indeed a y wind, 15 degrees.
          • Capt'n Crash
            • Mar 2015
            • 166
            Yes for y wind 4074 Leopard use 15 degrees.
            • Beaux
              • Dec 2015
              • 550
              capt n crash how is the timing adjustable on an elec. motor iam familiar with gas motors but this escapes me?
              • revoltrunner
                • May 2014
                • 646
                timing is adjusted on the esc not the motor.
                • Beaux
                  • Dec 2015
                  • 550
                  thanks
                  • Beaux
                    • Dec 2015
                    • 550
                    yep still confused
                    • Beaux
                      • Dec 2015
                      • 550
                      soooo the esc has diff. degrees in timing or calibrations built in ? would auto timing be just as effective would it adjust say from 0 to 15 or something like that ?
                      • revoltrunner
                        • May 2014
                        • 646
                        what esc are you using
                        • Beaux
                          • Dec 2015
                          • 550
                          a mystery 100 amp , w/3s 11.1 4400 on out board.
                          • Beaux
                            • Dec 2015
                            • 550
                            the motor starts off real soft then cones on pretty quick
                            • Capt'n Crash
                              • Mar 2015
                              • 166
                              Most esc's I'm familiar with have a program box that you plug into the esc to make adjustments to a variety of settings including motor timing. Most likely you need to find out what program box is required for your brand of esc and purchase it separately.
