New motor gives inconsistent power
  • Turbinen
    • Jun 2014
    • 12
    Hi!
    I just bought a new motor to my Apparition: a Leopard 3674, 1400kv, 2.5Y (the old one burned so this is a replacement)
    When I give throttle the motor gives a short burst - pauses - bursts - pauses and so on. Each burst and pause is about a second each. What is this??? I rechecked the ESC config and its the same as its always been:
    • PWM: 8kHz
    • 2-4 poles
    • Motor timing: 10 degrees
    What the bleep is this? I'm puzzled because its the same motor as before, but apparently the ESC doesen't understand that. Or?
    Has someone seen this before?
    T
  • ls1fst98
    • 905
    Back timing to 5 and see what it does, but sounds like something in the esc
    • Flying Scotsman
      Fast Electric Adict!
      • 5195
      What caused the last motor to burn out?...I would also suggest the ESC is toast.
      Douggie
      • Turbinen
        • Jun 2014
        • 12
        Douggie
        I'm not 100% shure but my guess is that the flexcable didn't have enough room to expand so it got stuck and caused way to high currents in the motor.
        Thanks for your thoughts
          Sounds like it's cogging. Likely the Esc is bad. In my experience when a motor fries it takes out the Esc too most of the time.
            Resolder the esc plugs, might have a cold solder joint or esdc is bad too.
