Motor spinning wrong direction?
  • jakevisser10
    • May 2015
    • 100
    I have the leopard 4074 2200kv and 180 amp esc combo from offshore electrics. I plugged it in and tested it and it is spinning the wrong direction for my prop. On my old boat I ran the same prop, and the polarity was right. Can I just switch the outermost wires on the motor/esc connection? Will this throw off the way my boat runs?
  • martin
    • 2881
    Swap any 2 of the motor to esc wires over.
    • Turbo Dan-O
      • Feb 2011
      • 301
      Yup, just swap them around and you will be fine. I always swap the positive and negative wires. Good to go!
      Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
      • Luck as a Constant
        Make Total Destroy
        • Mar 2014
        • 1952
        Huh?
          Brushed motor?
          Sent from my D6708 using Tapatalk
          • Turbo Dan-O
            • Feb 2011
            • 301
            Haha, brushless. I guess I should have said "Red and black" wires on the motor/ESC. I'm weird...
            • jakevisser10
              • May 2015
              • 100
              yeah its a brushless combo. I feel like an idiot after looking it over again last night I realized it was a switch on my transmitter....
              • kevinpratt823
                • Aug 2012
                • 1462
                Be sure to calibrate it if it is a new setup or if you reversed it on the radio.
                Sent from my SM-G920V using Tapatalk
                My private off road rc track
                • kevinpratt823
                  • Aug 2012
                  • 1462
                  Hold full throttle while you plug it in, after the beeps release to neutral.
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    Huh?
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      Throttle channel should be set to reverse on most radios. What radio?
                      • jakevisser10
                        • May 2015
                        • 100
                        Tactic 2.4
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          Yeah set throttle channel to reverse, turn throttle trim all the way up, then calibrate to your esc.
                          Once that's done, if your motor is spinning the wrong direction, simply swap any two of the motor wires.
                          Done
                          Easy
                          • jakevisser10
                            • May 2015
                            • 100
                            Alright thanks guys!
