timing on a Turnigy XK3674-2200KV
  • sram22
    • May 2015
    • 1
    could someone help me out with the timing to run on a Turnigy XK3674-2200KV Brushless Inrunner running 4 s set up and 120 amp esc
    Thanks matt
    • 9438
    It's difficult to give this advice not knowing if it is a "Y" or "D" wind. I know the Leopard 3674-2200kv motor is a "D" wind and uses timing in the 0 to 5 degree range. You can try this range first and if it gets too hot after 2 minutes running then it may be a "Y" wind that prefers 10-15 degrees timing.
    • runningman
      • Mar 2016
      • 103
      Did someone found out what wind this motor is?
        • 7990
        Two-year-old thread, the OP hasn't posted in years.
