Need Help with a Lehner 1940 4 wind motor
  • david hall
    • 111
    Tried a 1940 in a 2 lap boat this weekend. After the third time the motor unplugged it self we finally realized the windings and rear end bell is rotation in the can. If I hold the motor in my hand I can turn the windings and end bell by hand. Any suggestions?
    David
    How big is this boat? The windings are pressed in from what I understand. Where you over heating the motor? Little bit about your setup? 3919kv doesn't belong in very many boats unless it's quite small.
    • david hall
      • 111
      I have talked to Tyler and he will be able to take care of the issue. I purchased the motor used, I am pretty sure the person I got it from didn't know it had a problem. But the boat is a 28" JAE type hydro on 4S running a 40mm prop. Moderate load but not extreme. With a healthy motor this should be a pretty good 2lap setup. I was not able to run the boat long enough to get it warm, ESC had very short leads so it unplugged itself pretty quick.
      Thanks for the reply, David
      • NativePaul
        Greased Weasel
        • 2770
        I would say that with 3919 loaded kv on 4s in a JAE a 40mm prop would be an extreme load. On 4s I was pulling over 120A with a detouged x438 in mine on only 2700kv (unloaded).
          That was exactly my thoughts. But hey what do I know
          • Doug Smock
            • 5359
            Guys David knows what he's doing. He just set the fastest IMPBA 1/4 mile two lap record ever recorded with his T Hydro. 14.xx sec.
            But kids, don't try this at home.
            Congratulations on the record David!! Hope to see you guys soon.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • david hall
              • 111
              Paul and KFXGUY, thanks for the comments. If the setup was in a cat or mono I would agree. The JAE's are pretty efficient, I have attached a file below showing the current and temperature of the controller. The prop was a 1640 octura out of the bag. I wish I had noticed that I did not have all the options selected in the logging. I could usually run a little over a minute before it unplugged itself. The setup looked really good.
              • david hall
                • 111
                Doug Thanks, It was a lot of fun. Now the 10S setup is extreme. you have 3 laps, the 4th lap and the rotor comes apart. You still planning on making the august trial?
                David
                • Peter A
                  • 1622
                  14 sec., that is quick, a 14sec lap is fast, but two! Awesome stuff. Don't suppose there is a video of that?
                    [ATTACH=CONFIG]130706[/ATTACH]
                    Apologies, I wasn't aware of your experience. Most guys cannot get away with running a hot setup like that, the reason for my reply.
                    • david hall
                      • 111
                      14.610 1/4 mile 2 lap
                      Try This
                      Not a problem, I don't get on line very much.
                      • Doug Smock
                        • 5359
                        David
                        That hydro is sick David!
                        Yes sir, Huntsville in August is on the calendar!
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • photohoward1
                          • 1781
                          So 2 laps on an 1/8th mile track?
                          • RaceMechaniX
                            • 3024
                            David,
                            That is pretty efficient if you are only pulling 120A on a 4S set-up and still going that fast. I run about the same current in a heat race set-up for P Hydro with the 1415 1Y. Time to prop up.
                            TG
                            Tyler Garrard
                            NAMBA 639/IMPBA 20525
                            T-Hydro @ 142.94mph former WR
                            • david hall
                              • 111
                              Howard, yes, in IMPBA we have several legal courses that we can set records on. The 2 mostly used are 1/3 mile and 1/4 mile. The 1/4 mile record is made up of 2 1/8 mile laps. We start timing at buoy 1 and end at buoy 1. We did a straight line run with the boat without the turning just to check speed and it was running 97mph.
