SSS 3660 1620kv
  • airbiscuit
    • May 2016
    • 16
    Ah should've asked a better question. Here is my situation (as I posted on my other thread).
    My Pursuit is running Leopard 4074 2150kv with 4s1p (45c 5000mah) T180A v3 with M445 propeller. Timing is now set to 0*. Any higher, my electronics will become hot (or hotter) especially the esc. I am still having cutoffs at full throttle after few seconds of running. Releasing the throttle, I can go back running as normal & will only cutoff again if I go full.
    Hence why I asked running with 4s2p, will it "solve" the cutoff problem. As I see some using almost the same setup as mine but did not mentioned that they are having the same problem. Some did mentioned running 4s2p & some did not.
      • 7990
      The cutoff problem is the LVC in the ESC. Either it is set wrong or is malfunctioning. The T180s are notorious for the latter. Turn the LVC off and time your runs. The problem "should" go away.
      • airbiscuit
        • May 2016
        • 16
        To the OP, sorry for hijacking your thread.
        Yeah that is what I have been reading. It is set to 3.2v right now. I don't want to go lower as I don't want to risk over discharging my lipos. I guess I have to live with it then.
        Thanks Fluid.
        • boatsrnew2me
          • Oct 2016
          • 474
          going by the link provided to this stock motor it says it can handle 37 volts max .
          that said has anyone successfully run this motor on 6s without burning it up?
          • boatsrnew2me
            • Oct 2016
            • 474
            bump
            • boatsrnew2me
              • Oct 2016
              • 474
              bump.............anyone?
