ProBoat Impulse 31 v1 Motors
  • rhardy60
    • Jul 2013
    • 18
    I have the Impulse 31v1 ,I'm changing out the motor and esc . I'm putting in the Leopard 4074 Motor Brushless Inrunner 2000Kv 4-Pole and the Hobbywing Seaking 180A V3 Brushless Esc , is this a good setup to run 5s and 6s and can anyone till me what size the Bullet Banana Plug are on the motor side of the esc , any hep well b appreciated .
    VXL Rustler & Quanum Aquaholic Boat + 1 Seaport Tug + Slash 4x4 platinum & Impulse31 + Atlantic Harbor Tug .
  • Make-a-Wake
    FE Rules!
    • 6057
    Not sure why you would want to run 5 or 6s, 4s is plenty with that motor. 5s may be an ok setup with a smaller prop like an x440 but its really not necessary as you can prop up with 4s, x642 etc..........
    • petej
      • Jun 2010
      • 163
      Hi,
      I've been running my Impulse 31v1 with a 4074 1800kv Leopard, 5S 40C batteries, Seaking 120A ESC, Octura x645 prop for several years. Get's up near 60mph. Very reliable, easy on the electronics.
      Pete
      Motley Crew, Impulse 31, Zonda Cat, Genesis, Aqua Rider tug, E-Revo Brushless, Slash4x4
      • rhardy60
        • Jul 2013
        • 18
        Originally posted by petej View Post
        Hi,
        So in your opinion if i run the Octura x642 i should have pretty much the same result's ?
        • petej
          • Jun 2010
          • 163
          The x642, 4S, 2000kv is perfect. The 5S is just outside the range, but still OK. 6S on a 2000kv is too much RPM and will draw too much current.
          A lower kv motor will provide more torque for prop capacity (pitch, diameter) and can do so with higher voltage. Check out the OSE calculators to estimate speed an other metrics.
          Pete
          • siberianhusky
            • Dec 2009
            • 2206
            People are telling you the exact same thing on two different forums! Why do you not believe what people are telling you?
