Lehner motor timing
  • oscarel
    • Dec 2009
    • 2373
    Lehner motor timing
    I was going over the Lehner charts and noticed this "rpms are determined with 15° timing" and also the rpm ratings are based on delta (triangle) configuration. Also noted in the FAQ section is this
    Which motor timing value should I use?
    This depends on the load (small load - low timing / heavy load - high timing).
    A "compromise" clock value would be 10º - 15º.
    I'm currently running a 3080/8 in delta(triangle) at 2º which looks like it's way below what's suggested by LMT. What are those with these motors running???
  • RaceMechaniX
    • 3024
    15-20Deg
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • kevinpratt823
      • Aug 2012
      • 1462
      15-20Deg
      This is in Delta, correct Tyler? What would you be running if in Y?
      My private off road rc track
      • oscarel
        • Dec 2009
        • 2373
        15-20Deg
        Thanks Tyler!! And congrats on the speed record!!!! You need to update your signature :-)
        • RaceMechaniX
          • 3024
          Yes Thanks I will, but I am still recovering.
          15-20 for Delta
          20-22 for Wye
          These are estimates based on what I have recently seen. I would lower those numbers for motors that run longer than 1 minute. SAW motors can use slightly higher timing.
          TG
          Tyler Garrard
