What motor? Leopard 3674, Leopard 4074, or tp 4050
  • danallen
    • May 2014
    • 55
    Hello guys, I'm considering a new motor for my boat. I'm currently running a AQ1800kv 3656 out of a revolt, and I'm pretty happy with it, but would like more punch out of the hole, and maybe a bit more top speed, but mostly punch. I'm thinking that a larger motor with slightly more kv can swing an equal prop harder and faster, with the same or lower temps, yes?
    The the boat in question is linked in my sig.
    DF 29"
    seaking 180 v3
    AQ 1800 6 pole
    Octura x445
    4s lipo
    What Leopard or TP motor would you recommend for this boat?
    Thank you for your thoughts.
    -Dan
    DF29 - http://forums.offshoreelectrics.com/...ild&highlight=
  • jim82
    • Jan 2013
    • 1358
    Leo 3674 2200kv IMO. Is also a great motor for the revolt
    • jim82
      • Jan 2013
      • 1358
      With a leo 2200 on 4s of course, I would try an x442 as a start then move to an m445...After that and if is all good you want more speed or whatever try m545, and m645 but these cause more torque roll so you will have to teak it.
      • Luck as a Constant
        Make Total Destroy
        • Mar 2014
        • 1952
        I would go with the Leo 4074 only because I ran one for a long time and it was awesome.
        Tp I've never tried.
        Also the 4074 Leo is y wind which I prefer.
        I think the 3674 version is D? Which I don't care for
        • robinator63
          • 229
          I would say that the Leopard 3674 with your esc would make a very fast and reliable DF29. 2200 D wind for 4s. My 2cents.
            Both 3674 and 4074 would work well. If you are using 4s1p, I think the 3674 is the way to go. But if your plan is 4s2p, then why not the 4074. As Luck had said, I too have had great experience with the 40xx sized Leopard. (2200)
            Note that for a long time I shied away from D wind motor , but lately I have used a few TP motor that are "D" wind, as long as you set the timing accordingly, there is no drawback whatsoever.
            With the TP motor, I am partial to their 36xx motors but have not had any real world experience with their 40xx motor, the one I ordered had to be send back due to the front end-bell mounting holes out of spec ( this was a rare machining defect) and I could not mount it . Gave up, they gave me full refund and CS was good.
              I've had the same experience. I can't say whether the d wind draws more amps, but I've run the piss out my boat and it has run the same temps (motor cooler actually). I've said it before and I'll say it again, do not let the d or y wind be the deciding factor....the more important factors are the kv and can size. Just put timing at 0 for a d wind. I've read they have more top end. I cannot personally confirm this.
              As for the OP question, after taking apart the first leopard motor I ever have just last night...I can say I'm not a fan. The build quality looks shoddy at best. I'd recommend a castle 1515 or a tp 4050. The tp motors are built Suprisingly nice.....just make sure you add screws to the rear cap. (Castle would be my pick)
              • danallen
                • May 2014
                • 55
                Thanks all, this lets me know I'm thinking in the correct direction.
                I thought castle motors were finned and therefore could not receive a water cooling jacket. And can you elaborate on the adding of screws to the rear of the TP motors please?
                Thanks
                • danallen
                  • May 2014
                  • 55
                  And would this be better? http://www.tppowerusa.com/motors/bui...series/tp-3650
                  looking at the 3y config.
                    Thanks
                    They make coolers for the finned Castle motors. They sell them right here on ose. I have several of them. Here's one..
                    I don't think I would use a 36mm can motor btw...
                    The tp motors (well they used to be, not sure if they have changed) had the rear cap glued on. If I had one of those, I'd simply drill and tap for 3mm or 4-40 screws.
                      It should work, if you are looking at 4s set up with as much speed as possible without being impractical, a 2200kv will give you a bit more zoom provided you don't over prop it. The motor you quoted is north of 2000kv, actually it may be able to handle more prop, but it is a very long can and in this case I agree with Travis, might as well go for a 40xx sized can. The TP Travis pointed to you should be good for that purpose.
                      One really needs to see the inside of a motor to form an educated opinion. This much I can tell: I like the built-quality on the TP 36xx motors, it would not surprise me that their 40xx motors are built the same manner.
                      I never had a bad Leopard either, but I don't flock them to death as I neither race nor over power them. You should form your own opinion after reading a bit more.
                      The Castle Creation 1515 1y is a great motor, I have the green can finned version in my Insane Mono 34" running 4s2p, there is also a black version that is finned as well, they are almost the same but the motor end bell is a bit different and I personally prefer the green can as shown by Travis in his picture. Those motors were selling for $169 each and IMO is not to be confused with another version that is sold by TowerHobbies.
                      This is the one I like: http://www3.towerhobbies.com/cgi-bin...&I=LXZZZ5&P=SM
                      This is the one I suspect: it came as a combo with the ESC, but the price is suspiciously low:
                      http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXEBHZ, note that this is a smooth can. No one has tried this so far to the best of my knowledge here on the Forum.
                      Just to be clear: the black can 1515 finned Castle motor was made for Traxxas if I am correct, they are very good, have two . But for some reason if you pull and push the motor shaft by hand, the shaft/rotor on the green ones are absolutely stationary, no slack whatsoever, this is not true on their black finned motors, they do have some slop and as far as I can tell where as on the green ones the rear end bell is "sealed" , on the black ones the bearing is exposed, may be there is some internal difference in the bearing set up that can be attributed to this phenomenon.
                      Last edited by tlandauer; 11-05-2014, 12:55 AM. Reason: provide additional info on CC motors
                      • jkr
                        FE Addiction
                        • 582
                        Buy stronger lipos and smaller esc.
                        Stronger lipos will give you more speed and punch and a smaller esc like seaking 120 is almost half weight.
                        Jkr
                        • olwarbirds
                          Magic Smoke Wizard
                          • Oct 2012
                          • 1194
                          I run a Leo 3674 2200kv on 4S in a 29" mono running a 642 (worked !!) its fast and has been reliable. But, if you have the funds I would get the castle or Neu 1515, longer life, more power and bit less amp draw from what I've experienced.... DJ
                            Right now E-MAXX 2200 Kv motors (re-branded Castle 1515s) are available on eBay BIN for under $110. These are much better motors than Leopard or TP and will have more than enough punch for the OP's application. The T-180 will be more than enough for this motor on 4S - DO NOT go with a smaller ESC. Saving an ounce of weight is meaningless compared to not having to worry about cooking a cheap 120 amp ESC.
                            • danallen
                              • May 2014
                              • 55
                              Thanks, I didnt realise Castle 1515 motors could be had for pretty much the same price as the TP or leo. Really leaning toward the castle now.
