mean machine motor choice
  • montymike
    • 786
    Have a mean machine with a 4050 tp power 18003y m445 hobbywing 180 a on (3s)to hot of a setup thinking of going to a 2200kv (2s) setup need advice on motor thanks
  • Jdpb614
    • May 2014
    • 44
    My mm is running on a Leo 4082 1600 6s setup. Same prop and m545 temps are good haven't hit over 100-110 on my esc or motor.
    • montymike
      • 786
      men too fast for the pond that I driving in.
      • montymike
        • 786
        What size on 2 s 3674 2200, leo 4074 2200 leo, 4082 leo , 2220 tp power , neu 1y
        2200, thanks
        • 785boats
          Wet Track Racing
          • 3423
          If the 1800kv motor is too fast for you on 3s, why not try that motor on 2s first? It might bring you down to the right speed for your pond.
          Or alternatively try a smaller prop first.
          It could save you some money. And later on, when you find some bigger water, you can run it on 4s for some more speed.
            785 has it right. For another alternative, a 2200 Kv motor (any of the above motors will work, the more expensive the more efficient) on 2S and an m445 should give you speeds around 20-25 mph with low amp draw. A more aggressive prop like an x648 might give ~30 mph. Is that slow enough for your pond? If I was buying a new motor I'd probably choose a 3674 or 4074 with a Kv around 3000. With the m445 expect speeds around 30-35 and a bit fewer amps than you saw running 3S.
            • montymike
              • 786
              Am talking 3sx2=6s 1800 4050 tp power 65+ mph to fast for pond. Want to go
              To 2s1px2=4s 50s to hard on speed controler
              i run out of pond!
