Best motor for speed
  • conman13
    • Jul 2014
    • 10
    ok I am a newb to RC boats. I bought a Deep Vee 26'' boat hull from R2Hobbies (http://www.r2hobbies.com/rc-boats/ar...cing-boat.html) I got it today an hooked up the rudder and drive shaft. what I want to know is what motor I can install to make the boat go as fast as it can. I am using this ESC- (http://hobbyking.com/hobbyking/store...arehouse_.html). I was looking at this motor but I have no idea what the differences are between motors. right know I am just going by price. http://hobbyking.com/hobbyking/store...arehouse_.html
    -Connor McGrath
    Welcome to OSE! You should choose a water cooled ESC, the one in the link is not and is likely to overheat inside a sealed boat. The motor is suitable for 4S voltage, a good choice for a boat this size if you want high speed. Realize these are budget parts, they may work fine but maximum performance is better with higher quality parts. But as a starter boat they will go as fast as the hull can handle.
    • conman13
      • Jul 2014
      • 10
      ok thanks I will look into the ESC. I don't know if its possible to tell with the info I provided but what speed would you say the boat would max out at? also the website says that the motor can handle a 5s.
        For your info. I posted this to answer the other guy, this was not long ago:
        http://forums.offshoreelectrics.com/...ght=Impulse+26
        • iop65
          • Mar 2013
          • 367
          it's a 3974 can and only a 1200watt motor??
          you get that power from a 2860 size motor!!
          i don't think you can put in such a heavy /big motor in that hull : it's only 26"" and has a flood chamber ( limits the room inside)
          that motor will sink your boat :-)
          i suggest a 2860 or perhaps a 3660 size
          3000-3300 Kv a 3s lipo and a 38mm prop wil get you where you want with this hull
          my 2 cents
          • conman13
            • Jul 2014
            • 10
            my 2 cents
            ok thanks I think I will go with the 3400KV leopard motor. because the motor has a max og 80 amps does that mean that you cant have any higher then an 80 amp ESC?
            • iop65
              • Mar 2013
              • 367
              i had a 26" hull :leopard2860 2910Kv with a 38 mm 1.4P 2 blade tenshock prop , 3s 4000 40 c lipo , 90A seaking
              runtime 6-7 min , 60-65 km/H ,motor and esc barely warm
              i suppose but the 3400Kv ( also the 2860) will get it above the 70 km/h but will draw more amps turning that same prop , so i would go for maybe the 120A controller in combination with the 3400Kv
              i would suggest propping down at first runs : 36mm to get the feeling before searching for the limits (maybe the motor can swing a 40 mm prop,check the temps! )
              keep in mind that the boat probably isn't equiped with state off the art hardware so 37000rpm is going to be hard on the stuff
              • 785boats
                Wet Track Racing
                • 3423
                my 2 cents
                I have to agree.
                And that much spinning mass in such a small boat will cause handling problems in my opinion.
                I have had one of those hulls to build up for ages. Now I'm inspired.
                This is the motor I have for it. 1600 watts in a 29mm motor.
                http://www.hobbyking.com/hobbyking/s...ion_29mm_.html
                A 120A ESC, 4s lipo, a de tongued X440/3 blade prop
                That will be my setup.
                If you are going to run 3s, then this one might be an option. A bit less total wattage available but still more than the big Aquastar.
                • conman13
                  • Jul 2014
                  • 10
                  Thanks again for the help. I ended up getting a leopard 3650 4550KV motor running in a 3S 5000mah lipo 20c constant with 30c burst. Also got a 120amp hobbyking esc. I'm keeping the stick 34mm prop for now and will eventually upgrade it. Hoping to run it on this setup for the first time tomorrow.
                  • madmikepags
                    • Aug 2012
                    • 1371
                    what???? am I reading this correctly??? 4550KV on 3s = 50,000 rpm??? a 120amp speedo?? = smoke??? My race setups on ALL OF MY BOATS are between 27-32,000 rpm. Oh and 20C batteries??? prepare for more smoke? You should really read up a bit more on setups and how to calculate rpm and amp draw, but what you have is a recipe for failure and fire.
                    We call ourselves the "Q"
                    • conman13
                      • Jul 2014
                      • 10
                      do you mind explaining more??what should I do to fix the danger in this?
                      • olwarbirds
                        Magic Smoke Wizard
                        • Oct 2012
                        • 1194
                        Lipo: 20c at 5000mah = 100 amps constant 30c burst = 150 amps ...Motor: KV = rpms per volt a 3S lipo full charged = 12.6v so 12.6 x 4550 = 57,000 rpm and your using a plastic prop thats going to come apart....You asked for advice and ignored it, make sure no innocent bystanders get hurt....bring a good fire extinguisher
                        Do some research, your motor is to big and to high a kv for that boat and esc its going to pull more amps than esc and lipos can handle....40c minimum is what I suggest to all my boat customers..check out the speed calc up top of page to start....save that motor for a hot 2S boat
                        • conman13
                          • Jul 2014
                          • 10
                          I know ok I get it I made a mistake this is my first time with RC boats. I asked what I could do to make it safe to run.
                          • iop65
                            • Mar 2013
                            • 367
                            good thing you asked before putting that in the water!!
                            but ,good advice was given and you ended up with that!
                            last try :
                            i can't see but: is that esc watercooled?rather usefull in a FE!
                            that coupler is a real danger for your boat ,yourself and anyone close, my god! please don't use that
                            motor not ideal but will do :good size but wrong KV so only and only using 2s!!!!!!
                            that toy prop : i wouldn't trust it
                            • conman13
                              • Jul 2014
                              • 10
                              last try :
                              ok thanks yes the esc is watercooled. I will get a 2s lipo to run it on and another prop. I will get another coupler but don't understand what is wrong with this one.
