Water cooler for Castle (NEU) 1415 2400kv
  • longballlumber
    • 3417
    I am looking for a water cooler that will work for the Castle 1415 motor.
    I purchased and tried one of these from OSE, but it still leaks, I would like to avoid installing using silicon.
    http://www.offshoreelectrics.com/pro...prod=ose-80030
    Does anyone know of a can that can be installed correctly and doesn't leak?
    Later,
    Mike
    I have one similar to this one: http://www.offshoreelectrics.com/pro...e-80959-jacket
    Mine works fine with no leaks but it is not identical to the one in the link above, it is black and I can't remember where I got it. The one you showed looks too short. Here is a shot of mine, it covers all the grooves:
    • longballlumber
      • 3417
      Thanks Jay,
      Your right, the one I have is probably a little short and sits in the small groves of the motor not getting enough interference when installed. I may give this one a try.
      Thanks,
      Mike
        I used the 36mm long one for mine. No issues. I'll look in my acct folder and see which one.
          Upon measuring mine on the bench, I have this http://www.offshoreelectrics.com/pro...ham-jack-540XL
            I believe mine is 60mm long, it is for a 540XL motor. It is not "tight" on the 1415 can but it doesn't leak on a 70 mph rigger.
            • sapdforu
              Loose nut
              • Apr 2014
              • 88
              I use a xl cooling jacket, if I put it next to the motor mount, it will leak, if I put it next to the wires, it wont leak.
              H&M Supercat S 73mph; Daytona Twin 89.73mph
              Bandit carbon fiber Larsony, 70mph; pursuit.... too slow
              • longballlumber
                • 3417
                Thanks for the replies guys, I have a couple different ones coming from OSE to try.
                Later,
                Mike
                • longballlumber
                  • 3417
                  For those of you following along in this thread; this cooling can won't work it's too long http://www.offshoreelectrics.com/pro...e-80959-jacket
                  I am going to try this next http://www.offshoreelectrics.com/pro...ham-jack-540XL We will see.
                  Later,
                  Ball
                    I am pretty sure that is the one I have on mine.
