Brushless motor cleaning !!!!!
  • flraptor07
    • Aug 2013
    • 2451
    Best $60.00 I've spent in a while, no more burnt up ESCs http://www.hobbypartz.com/26p-motorc...FW1nOgodGx8ATA
    • Albert M
      • Jan 2014
      • 34
      After cleaning the motor with Pb blast and denature alcohol it cleaned up pretty good bearing feel pretty smooth ! Servo and receiver are in working order only the Esc burned out .....
      • motorfixer1
        • May 2012
        • 41
        You could take an Ohm meter and check the resistance across all three leads. 1-2, 1-3, 2-3. They should be even and low resistance. Then check between each lead and the case of the motor to check the insulation. An ohm meter is not as good as a megger but it's better than nothing. It is bothersome that your esc went poof.
