Question on Original SV 27 BL motor
    I have acquired a Vac-U-Pickle that came with an old/original AquaCraft Super V 27 BL motor, according to OSE, it's 1700kv.
    I find the cogging to be tremendous---I can hardly turn with my hand
    How is it compared to the newer 1800kv motors. Is it less powerful and noticeably slower? Plan is to use an UL-1 motor, but for now I want to see if this motor would give me a feel of how the boat would run.
    Advice and suggestions would be greatly appreciated.
    Cheers
    • 7512
    The cogging is normal for that motor. I have 2 and they are the same.
      Thanks!
      Anybody did back to back comparison with the 1800kv?
      • monojeff
        • Nov 2010
        • 2728
        I can tell you from my experience with the blue can sv motors they are faster then the 1500kv motors but generate a heck of a lot more hear with same prop. Keep to 45mm prop and you will be fine
        I can push a lot more prop with 1500kv motor and be similar speeds.
        I burned 1 up in my 1/10 shovel after 1 season of racing the inside glue let loose from heating up.
        So with that said newer motors seam to handle hear and being pushed a bit better IMO.
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • Alexgar
          • Aug 2009
          • 3701
          imo i thimk the pb 1800 motors are higher torque and quality than the aq motors
            Thanks for the feedback, guys!
            I was very fond of the AC 1800kv and 2030kv motors. They are relatively economical to acquire and the ones I had several years ago seemed to last forever. That is until recently I burned a brand new 1800kv motor in my MG, the set up was normal. m445 prop and running 4s2p with the SK180 ESC. The wires just melted and started a short, the insulation was not damaged at the exit as I TRIPLE checked before using the motor. I did not think a new motor needed Properchopper's treatment, and boy, was I wrong . Not sure I want to buy another one.
            The Proboat motors are good but I am looking now for a 2000+kv motor ( UL-1), to up grade from the original SV27 blue can motor, wonder if the problem also applies to the 2030kv as well.
              I was sufing the web, came upon this: http://www.xtmodel.com/en/Products/product_55.html.
              orderd the 2100kv/2Y in place of the AC 2030kv (UL-1 MOTOR)
              Let's see first if my order arrives, and then how it perfomes.
              This is gambling!
