Ooh, probably not too quick. But you never know. I don't have any issue with them. May take a day or two to get out for you. Once in mail it'll go quick. They are in Ft. Lauderdale
It has been like that for awhile now. Let Kevin at FighterCatShipping@gmail.com know what you want exactly and where you are located and he will get back to you.
He emailed me right back at 12:30am our time and took my order through email. Now that's customer service....
Even said he will ship it out first thing in morning. Kevin at FCR you are the man thx again Slash
Never knew that, thanks for the link!
Question: if this ring goes infront of the wire exit, is there enough room for the water cooler? On the TFL "standard" mount, a motor of 4074 size would pretty much "push" the ring to the very end of the motor, so I thought on the Castle 1515 the wire exit would have interfered with the ring unless one mounts the rear ring in front of the exit and drills a new set of holes on the rails, use a water jacket no longer than 50mm, even then it is tight, no?!
I have two of them running now mind you I made custom side rails for both my Geico and Bling Rocket. You may need to move or elongate some mount holes. On my Geico I am pretty sure I just needed taller rails though and that was why I fabbed some sides.
