Motor Mount Jae21
  • ezhitz
    • Aug 2009
    • 466
    Motor Mount Jae21
    I was wondering the zipp kit motor mount for the Jae says its for a 36mm dia. motor but would a 40mm motor also fit.
    If not what mount do guys use when not using the UL1 motor.
    Thanks
    :canada
  • RayR
    @SiestaKey.calm
    • 1591
    Most 40mm motors use the same 25mm hole pattern as the UL-1 motor.
      It depends on the water cooling jacket you use. Some are very close to the spacing between the mount legs and may have an interference issue. Thinner jackets should work okay. I use a Castle 1415 motor (36mm) without problems in my JAE 21FE, it runs low 70s depending on the prop.
      • martin
        • 2881
        A few have fitted Leopard 4082 motors in the JAE, a small mod is required to the stock mount. Its a simple mod that can be done with a half round file where the side angles need a radius filed to allow the motor end cap to sit on the Zipp mounting plate.
        • ezhitz
          • Aug 2009
          • 466
          Thanks for your answers, I will be trying a TP 4050 so I think I will be ok. The water jacket is thin.
          :canada
          • martin
            • 2881
            As an example a Leopard 40 series cooling jacket clears the mounting legs 2mm either side.
            • martin
              • 2881
              The width between the mounting legs on the Zipp mount is 51mm & the Leopard jacket is 47mm.
              • martin
                • 2881
                With the larger size motors you will have to do some mods to the hatch opening to make it a bit wider to get the motor in & out, you may have to mod the hatch to clear the longer & wider motor & jacket as its very close to the hatch.
                • longballlumber
                  • 3417
                  Which cooling Jacket are you using with the Castle 1415 and still able to get it into an "as designed" JAE?
                  Thanks,
                  Mike
                    A jacket for a Feiago 540 fits. It's not as tight as other jackets but so far no leaks. It isn't this exact jacket but very similar.
                    http://www.offshoreelectrics.com/pro...e-80959-jacket
                    • JohnZ
                      • 267
                      what are you going to use for batteries? I have one of those still in the box. The Leo 4050 looks good but I'm also looking at TP Power motors.
                      • ezhitz
                        • Aug 2009
                        • 466
                        I have a couple Dinogy 65c 5000mah I will use.
                        :canada
