Best prop for a 1500 kv 4082 turnigy motor and t-180 esc.
  • shartinspartin
    • Aug 2013
    • 257
    Im wanting to know the best prop to put on this combo. (pushin a 36 inch abs deep v hull)
    Thanks
  • greenblast
    • 301
    no to be offensive> your question is equivalent to how much is a car by the pound. be specific you will find your answer
    • shartinspartin
      • Aug 2013
      • 257
      I dont want to be too specific because my sub forum is dead... but its a spartan
      • Heaving Earth
        • 1929
          What prop do you have on hand and what connectors are you using ?
          You should be running 5.5 bullets all the way in the setup.
          I would try a three blade it should help control with torque roll in that hull,
          Some props that I would try are a x646/3 and a x447/3 and so on.
          Do some test runs for 1 1/2 minutes and check temps on everything and motor connectors to,
          Also if you have a gps get some speed readings to.
          • shartinspartin
            • Aug 2013
            • 257
            5.5 mm bullets. from what Ive read nobody has had luck with 3 blade props on this boat.
            • 785boats
              Wet Track Racing
              • 3423
              Although you haven't stated it, I assume that you are running 6s packs?
              If so, then a Prather S215 works very well.
              • shartinspartin
                • Aug 2013
                • 257
                yes 6s. Well thats good because I hace a prather 215 =)
                Is this prop more pitch than stock?
                • 4sdash
                  • Sep 2013
                  • 54
                  im running a 642 on my spartan
