leopard 3674 motor bearing change out problem
    • Jul 2011
    • 153
    I have leopard 3674 1650kv motor I sunk, had to change out the bearings, lost one of the spacers, now I have slop on motor shaft. can anyone tell me the spacer size that should go on each side of motor armature?? there is one thick one on one side and 2 thin ones on the other, but still Im getting slop?
  • martin
    • 2881
    Not sure whether you mean you have lost a spacer & have lots of slop on the motor shaft or if theirs a small amount of play you have. The Leopard motors do come with end play on them around 0.2mm or .008".
      • Jul 2011
      • 153
      hi, when I took out armature from can I lost a spacer, a buddy gave me the same one, now motor sounds loud compared to my other new one? do you know what size spacers goe where on this motor? theres 2 thin ones and a 3mm thick one.
      • m4a1usr
        Fast Electric Addict
        • 2036
        Depending on rotor location, relative to the armature in the motor, your best option might be to measure one side or both ends of the rotor while it sits in the motor. Typically a motor, like a Castle, has the longer spacer at the rear. But since all motors are a bit different in construction a measurement would tell you what you need to know. As far as the new bearing motor being louder it might be due to how you pressed in the bearings. Pressure or force to install the bearings should only be applied to the outer race. Never apply force to the inner race since side loading can and will damage the new bearing. And that might have happened in your case.
        John
        Change is the one Constant
          • Jul 2011
          • 153
          how would I get the bearings in without wrecking inner walls, dont have the right tools.
          • JrValente
            • 105
            I have used sockets that will apply pressure to the outside race in the past.
              • Jul 2011
              • 153
              motor
              did you use a drill press to apply pressure to bearings?
              • JrValente
                • 105
                Nope just a socket and a dead blow with a touch of oil on outside of bearing to ease into place.
