neu 1515 2200kv and castle creations 2200kv performance differences
  • Gen
    • Dec 2010
    • 130
    I know a well setup boat will go lots faster. I gained 7mph after sending tony a email start of last year. I just always thought lifting timing would increase temps (its definetly the case with cars) will see how i go with speed. Runtime and temps as we need the best combo of all 3 to be smiling.
    • Gen
      • Dec 2010
      • 130
      well went for a run today .with 15 degrees timing temps were exactly the same as previosly logged with 10 degrees timing so i might go a bit more mabee 17 degrees .as this made no difference to temp .
      temps after 4 min runs were cool for motor just over 100F batterys 110F but hydra 240 was hotter than i would like it to be 140F .
      boat seemed fast boat was super stable and seems to be setup and running well ,
      when i get down low i can see that front sponsons are just coming out of water .but not really likely to catch air .
      but not faster same speeds 59mph however main lake was too windy to run on so i went to another lake which is small can only get on gas for 140/150 ft till i gotta slow down .. so mayu have been able to a get a few more mph with a bigger lake ..
      i think im going to put another pick up on boat do the underhull pickups work well or are the transom pickups a lot better (hate the look of these)
      but this wont drop the temp of my esc 30F will it .?
      fyi my water pickup from rudder goes into motor first then hydra esc 2nd then out of hull so boats already getting warm water after motor to esc ..
      also gonna get a m545 sharpened to try ..
      • SirBudman32
        • Aug 2011
        • 701
        I ran dual pickups on my Genesis. They where under hull pickups. But if you are running only one pickup you should cool the esc first.
        Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
