Which motor is better?
  • Jason4636
    • 712
    I would say since your running a 54" hull and you have the space for batteries. I would run a comparable size to a 40mm or a 56mm at what voltage you wanna run. Do you wanna run 1p or 2p?
    • Alfa Spirit
      • 2183
      I vote for two SSS 5684 1000kV or two TPPower 4060 (40x92) 6Y 980kV. And if you want long run time use 3 x 10S wired in parallel for the 2 combos
      • MrUnlimited
        • 94
        Jason:
        10s2p packs for each motor.
        Alfa: have you run those motors and how do they perform?
        • Alfa Spirit
          • 2183
          A friend of mine run 2 x TPPower 4060 980kV wih 8S 3p in a deep vee 147cm long (59" )
          • Jason4636
            • 712
            I'm going to run 8,9 and 10s2p in my mono. With twin 528's. With the right props on 10s you could hit 80mph. I think I'll just prop my mono to top out at 70mph. After I get done with it and the paint job is done. I'll be afraid of crashing it
            • Old Sloppy
              Harry from Atlanta
              • Jul 2007
              • 201
              What do you guys think of the Leopard 56-110 780 Kv motors on 10s ?
              How many watts are they rated ?
              don't mean to hi-jack this thread............
              Thanks,
              Harry
              60" Expresscraft SuperCat
              (2) 2028 Castle motors 64.7 mph
              10s3p with x450/3 props
              15,000 mah 40c cells,
              • MrUnlimited
                • 94
                56 size Leopard motors on 10s:
                • MrUnlimited
                  • 94
                  From what I read in other threads is that the Leo's are getting hot and the quality is not that high as the TP power motors. read the new PROTUES motors are a beast so I think I am gonna order a pair of X524 910KV motors and run them on 8s packs. Good choice Keith?
                  • Alfa Spirit
                    • 2183
                    Do you think about the weight? 1035 Grammes
                    2 x 8S
                    2 x 10S
                    • keithbradley
                      • 3671
                      There are a million ways to go with a hull this size, but that should work for sure...what are you trying to do with it? Go carzy fast, or just a "sport" type setup?
                      www.keithbradleyboats.com
                      • Old Sloppy
                        Harry from Atlanta
                        • Jul 2007
                        • 201
                        i would go with the 6,300 watt rated motor...
                        Harry
                        • MrUnlimited
                          • 94
                          My attempt is to go over the 100mph or more with some modified props
                          • MrUnlimited
                            • 94
                            2 x 8S
                            [ATTACH=CONFIG]91099[/ATTACH]
                            2 x 10S
                            [ATTACH=CONFIG]91100[/ATTACH]
                            No I don't want to burn out the motors. The Protues 910KV motors are rated 33volt max although the leopard 5692/1090 are rated the same and the guy i movie I placed in this thread is using 10s.
                            • MrUnlimited
                              • 94
                              Keith?
                              • keithbradley
                                • 3671
                                If you want to go over 100, you might want a more RPM capable motor, like a Lehner or Neu.
